Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > The Matrix > Выпивка в Матрице
Выпивка в Матрице
Это из бара в Hel Club
http://www.liveinternet.ru/images/attach/687722/1179955.jpg
кто разберет?
Штирлиц в оффлайне Old Post 20.09.2004 07:04
[CPR]-AL.exe
Yellow Energy какой-то. А стаканы у них чище чем бутылки с пойлом. (Судя по архивам Зиона (http://whatisthematrix.warnerbros.c...s_frameset.html)
Дело не в тебе
Последний раз сообщение редактировалось пользователем [CPR]-AL.exe 20.09.2004 в 09:10
[CPR]-AL.exe в оффлайне Old Post 20.09.2004 08:45
[CPR]-AL.exe
Немного по занимался нетраннингом и нашел вам цитату про йеллоу повер:
From the vantage point of the octarine gnosis, the magician self should be able to perceive the selves of the other seven powers, and be able to see their interrelationship within his total organism. Thus the octarine power brings some ability in psychiatry, which is the adjustment of the relationship between the selves in an organism. The basic difference between a magician and a civilian is that in the latter the octarine power is vestigial or undeveloped. The normal resting or neutral mode a civilian corresponds to a mild expression of the yellow power which he regards as his normal personality or "ego". The magician self however, is fully aware that this is but one of eight major tools that the organism possesses. Thus, in a sense, the "normal personality" of the magician is a tool of his magical self (and, importantly, vice versa). This realisation gives him some advantage over ordinary people. However the developing magical self will soon realize that it is not in itself superior to the other selves that the organism consists of, for there are many things they can do which it cannot.
Философия, эго!!!!
Вачовски форева happy
Полный текст тут: http://glaz.pesni.ru/books/magick/PC_LK.htm
Дело не в тебе
[CPR]-AL.exe в оффлайне Old Post 20.09.2004 09:01
[CPR]-AL.exe
А вот еще что нашел по запросу "желтая энергия":
ЖЕЛТЫЙ ЦВЕТ выполняет очень много разнообразных функций в плане физиологии, мышления, эмоций, деятельности в обществе.
Начнем с физиологии.
Это пищеварение и обмен веществ. В частности водно-кальциевый обмен. Если желтой энергии недостаточно, то будут проблемы с желудком, печенью, поджелудочной железой. Пища будет плохо пе ревариваться, и значительно ухудшится извлечение кальция из пищи с одной стороны, и, с другой ст ороны, отложение его солей в костях. Тело утратит гибкость. Ухудшение памяти, снижение жизненной активности - тоже следствие недостатка желтой энергии. Появляется усталость, сонливость, нежела ние действовать.
При достаточном колличестве желтой энергии, восстанавливается нормальное пищеварение и усвоение кальция. Рассасываются отложения солей, появляется гибкость в теле и желание действов ать. Человек становится веселым и жизнерадостным. Восстанавливается память и живость ума. А вмес те с ней приходит успех в делах, особенно это касается денежных вопросов. Ведь желтый цвет - это цвет золота. И здесь существует прямая связь. Есть желтая энергия - есть деньги, есть финансовый успех.
Мышление. Желтый цвет улучшает память, активизирует умственную деятельность, особенно то , что связано с практической деятельностью. \'Желтый ум\' - смекалистый, можно сказать, даже хитрый и изворотливый. Люди у которых много желтой энергии, обычно хорошие специалисты в разных областя х, и у них хорошо идет мелкий и средний бизнес.
Эмоции - радость, веселье, жизнерадостность. Желтый цвет делает человека заводилой в комп ании, в обществе с такими людьми всегда весело и интересно.
Деятельность. Желтый цвет можно называть главным двигателем у человека. Он не дает ему с идеть на месте. У такого человека все горит в руках. Любая работа делается легко и быстро. Желтый цвет приносит успех в бизнесе. Не даром золото желтого цвета.
Прочитав эту короткую характеристику желтого цвета, вы поймете насколько он нужен каждому челов еку. Ведь все хотят быть здоровыми, богатыми, успешными и веселыми.
Участвуя в настройке на желтый цвет, вы поможете и себе другим людям. Наш мир станет на капел ьку лучше, чище, веселее, а значит и счастливее.
Дело не в тебе
[CPR]-AL.exe в оффлайне Old Post 20.09.2004 09:09
[CPR]-AL.exe
КАК ВСЕ ПРОСТО!!!!!!!
Я-то думал...
Ответ здесь:
http://www.potrebitel.ru/newweb/goo...omments&id=3892
Кратко:
Yellow Energy
ТИП: энергетический напиток.
СТРАНА-ПРОИЗВОДИТЕЛЬ: Австрия.
ЛИТРАЖ: банка 0,25 л.
ЭНЕРГЕТИЧЕСКАЯ ЦЕННОСТЬ: на 100 мл — 55 ккал, белк — 0, жиры — 0, углеводы — 13,3 г.
ОСНОВНЫЕ ИНГРЕДИЕНТЫ: таурин, кофеин, инозит.
СОСТАВ: вода, сахар, угольная кислота, лимонная кислота, таурин (400 мг/100 мл), окисляющий регулятор: трисодиум цитрат, кофеин (32 мг/100 мл), краситель Е150d, ароматизатор, инозит (32 мг/100 мл), никотинамид (7,9 мг — 44%), витамин В6 (2,0 мг — 100%), пантотеновая кислота (2,0 мг — 33%), витамин В2 (0,53 мг — 33%), витамин В12 (2,0 мкг — 200%).
СВОЙСТВА: в напитке содержится почти полный набор витаминов группы В, понемногу каждого (В2, В3, В5, В5, В12 — в избытке). Это плюс, поскольку чаще всего организм недополучает именно их. Кофеин бодрит и борется со сном, а таурин регулирует сердцебиение, поэтому такое сочетание присутствует почти во всех энерготониках. Кроме этого, таурин способствует усвоению жиров и жирорастворимых витаминов.
ЦЕНА: 30 руб.
Дело не в тебе
Последний раз сообщение редактировалось пользователем [CPR]-AL.exe 21.09.2004 в 12:26
[CPR]-AL.exe в оффлайне Old Post 20.09.2004 09:13
Пивасик - бутылочный - Нео в клубе.
самогонка Дозера.
Сайфер - конъячок?? хотя скорее винище - подливают ли конъяк КУВШИНАМИ?
Бомж в метро - не удается идентифицмровать.
Выпендрежник Мерв - Шато От Брийон 1959 года и мартишок.
Женщина в розовом - тоже вино.
Что еще?
Штирлиц в оффлайне Old Post 20.09.2004 18:32
[CPR]-AL.exe
Женщина в розовом? Которой камера между ног влетает? В ресторане(Le Vrai )?
Дело не в тебе
[CPR]-AL.exe в оффлайне Old Post 21.09.2004 08:40
[CPR]-AL.exe:
That's true.
Штирлиц в оффлайне Old Post 21.09.2004 10:00
[CPR]-AL.exe
ВНИМАНИЕ: Чтобы просмотреть информацию по этому ВОПРОСУ ПОЛНОСТЬЮ, воспользуйтесь Энциклопедией Матрицы в разделе форум/the matrix
Дело не в тебе
[CPR]-AL.exe в оффлайне Old Post 21.09.2004 12:28
Время на форуме соответствует Гринвичу . Сейчас время - 07:08. Новая тема   Ответить
