Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > ARC Raiders: Outstanding Balance Quest Walkthrough and Tips
FlameViper
На форумах с июля 2025
If you are working your way through the vendor progression in ARC Raiders, you will eventually unlock the Outstanding Balance quest. Handed out by Tian Wen, the reliable gun-shop owner back in Speranza, this mission sends you deep into hostile territory to track down a missing stash and recover a vital piece of intel.
The entire quest takes place on the Blue Gate map. While it might look intimidating with heavily patrolled sectors and rival players scouting the same paths, you can actually wrap up the whole questline in a single clean run if you know the exact route to take. Here is a straightforward, player-perspective breakdown of how to get in, secure Dodger's note, and make it out alive.
Quest Overview
Quest Giver: Tian Wen (Speranza gun-shop owner)
Objective: Search the Traffic Tunnel, check the Pilgrim's Peak antenna, and retrieve Dodger's Note.
Rewards: Gothic graffiti, Aviator color, Extended beauty mag #3, and a Silencer 2.
The Ideal Pathing
To complete this efficiently without wandering into dead ends, you should tackle the objectives in a linear sequence before heading to extraction:
[Start: Blue Gate] ➡️ [1. Traffic Tunnel Stash] ➡️ [2. Pilgrim's Peak Antenna] ➡️ [3. Secure Note & Extract]
Step-by-Step Walkthrough
1. Search Dodger's Stash in the Traffic Tunnel
Once you deploy into the Blue Gate map, your very first destination is the Checkpoint point of interest (POI), which sits right in the central region of the map.
Locate the Entrance: Look for the massive industrial doors around the Checkpoint area. These lead directly underground into the dark, concrete corridors of the Traffic Tunnel.
Finding the Cache: Head inside and stay focused on the main underground road. Move northwest, hugging the left-hand wall. Keep an eye out for a large, distinct blue tarp near the back wall of the tunnel system.
Trigger the Interaction: Underneath the tarp, you will spot a crate labeled Dodger's Stash. Walk up and interact with it. A quick word of warning: as soon as you hit the prompt, step back immediately. The container triggers a small, explosive breach effect when opened. Once the smoke clears, you will find out the stash is completely empty. This empty container is the trigger that updates your quest to the next stage.
2. Search Dodger's Deal Spot at Pilgrim's Peak
With the tunnel stash coming up empty, you need to head over to Dodger's backup location at Pilgrim's Peak. This is the unmistakable, massive antenna structure situated in the northeast sector of your map.
Scale the Structure: Approach the antenna building from the rear. Look for an open access point where an internal zipline is hanging.
The Mid-Way Drop: Hop onto the zipline to ride it upward. Do not ride it all the way to the absolute top. Instead, time your jump and detach at the halfway mark, which lands you right on the generator level (the second floor down from the summit).
Grab the Note: As soon as you land on the metal grating, turn immediately to your right. Tucked tightly against some heavy storage containers is a small, bright yellow tool bag known as Dodger's Bag. Loot the bag, and Dodger's Note will drop straight onto the floor. Make sure you physically pick it up from the ground to put it in your inventory.
3. Extract and Deliver
Now comes the most important part: keeping the note safe. You need to carry this item out of the zone successfully. Head to the nearest active extraction zone, call down your ride, and defend the position.
The moment you successfully extract from the raid, the quest automatically completes. You can then head over to your main menu vendor screen, chat with Tian Wen, and claim your hard-earned weapon parts and cosmetic rewards.
Pro Tips for Survival
Equip a Safe Pocket Augment: This is easily the most critical tip for this quest. The very second Dodger's Note hits your inventory, open your gear screen and drop it straight into your Safety Pocket. The Blue Gate map is highly volatile, packed with aggressive ARC Drones and opportunistic rival Raiders. If you get caught out and eliminated before reaching the extraction ship, having the note in your Safety Pocket guarantees it stays with you, saving you from having to run the entire quest chain over again.
Move with Stealth: The terrain connecting the central Traffic Tunnel and Pilgrim's Peak is a notorious hotspot for enemy patrols and player ambushes. Avoid the temptation to clear out every group of bots you see. Suppress your weapon, use cover, and keep a low profile to avoid giving away your location to nearby squads.
The Fast Route Execution: If you want to minimize your time in the danger zone, treat this as a textbook speedrun. Drop in, sprint straight into the underground tunnel entrance, click the container, and exit through the northern tunnel threshold. From there, make a hard line to the rear zipline at the peak, grab the note from the yellow bag, slide it into your safe pocket, and call the closest available extraction point immediately.
FlameViper в оффлайне Old Post 14.06.2026 23:54
Время на форуме соответствует Гринвичу . Сейчас время - 23:43. Новая тема   Ответить
