Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Flame > Игротека > KNX Touch Panel
KNX Touch Panel
In the world of smart homes and building automation, the KNX protocol stands out as a reliable and internationally recognized standard. To create a seamless user experience, a touch panel becomes the core interface between people and smart systems. The Portworld SM41P KNX edition is designed to be a compact yet powerful solution for high-end residences, hotels, apartments, and commercial spaces.
Compact but Powerful 4-Inch KNX Touch Panel
The SM41P KNX Touch Panel features a 4-inch capacitive touchscreen with crisp display quality and smooth touch interaction. Its compact design allows it to fit perfectly into a standard 86-type wall box, blending seamlessly with any interior design.
Specifically developed for KNX integration, the panel supports direct communication with KNX bus devices without requiring additional gateways. It enables:
Lighting control (individual circuits or scenes)
Curtain and blind control
HVAC and floor heating management
Security and status monitoring
Hardware & System Features
Processor: High-performance, low-power chipset for 24/7 stability
Operating System: Pure Android 11, supporting secondary development and customization
Installation: Wall-mounted, standard 86-type back box compatible
Interfaces: RJ45 (with optional PoE), RS485, KNX bus interface
This combination allows the SM41P KNX version to function as a standalone control unit or integrate seamlessly with building management platforms and third-party systems (e.g., BACnet, Modbus).
https://portworld-solu.com/why-does...-and-solutions/
https://portworld-solu.com/how-to-f...control-panels/
https://portworld-solu.com/brillian...-control-panel/
https://portworld-solu.com/best-tou...and-thermostat/
https://portworld-solu.com/smart-ho...android-models/
https://portworld-solu.com/how-do-i...ogle-assistant/
https://portworld-solu.com/how-can-...ome-controller/
https://portworld-solu.com/what-mak...better-for-you/
https://portworld-solu.com/how-port...try-challenges/
https://portworld-solu.com/brillian...h-panel-dimmer/
https://portworld-solu.com/what-is-...-control-panel/
https://portworld-solu.com/wholesal...lier-portworld/
https://portworld-solu.com/comparat...control-panels/
https://portworld-solu.com/what-are...ntrol-products/
https://portworld-solu.com/explorin...utions-compare/
https://portworld-solu.com/how-to-s...-control-panel/
https://portworld-solu.com/how-to-c...ogle-assistant/
https://portworld-solu.com/why-are-...g-more-popular/
portworld в оффлайне Old Post 29.08.2025 23:23
Время на форуме соответствует Гринвичу . Сейчас время - 13:26. Новая тема   Ответить
