Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > Extinct Matteo in Steal A Brainrot – Complete Unlock Guide
FrostWhisper
На форумах с Aug 2025
For players diving deep into Steal A Brainrot, unlocking Extinct Matteo can be a game-changer. This guide breaks down everything you need to know to obtain this elusive character and maximize your in-game strategies.
Where to Start
Extinct Matteo is not available from standard drops in most early-game areas, so targeting specific sources is crucial. Experienced players often check the Steal a Brainrot store for limited-time offers, as this is one of the more reliable ways to acquire rare characters without relying solely on luck.
Methods to Unlock Extinct Matteo
Fusion Strategy
Matteo can be obtained through certain fusion combinations involving high-tier characters. Make sure you have gathered the necessary materials before attempting a fusion, as this method can be resource-intensive. Knowing the exact fusion recipe is key, and tracking it through community guides or platforms like U4GM can save time and frustration.
Event Rewards
Occasionally, special events reward players with Extinct Matteo or the materials needed to unlock him. Keep an eye on announcements and participate actively, since these opportunities can be fleeting.
In-Game Store
If you prefer a more straightforward route, you can buy SAB characters directly from the Steal a Brainrot store. While this requires in-game currency, it is often the fastest way to secure Matteo, especially if you’ve been collecting resources steadily.
Tips for Success
Prioritize leveling up the characters needed for fusion first; a failed attempt can be costly in both time and materials.
Track updates on platforms like U4GM, where experienced players share insights and tips on the most efficient methods to obtain rare characters.
Keep a balance between farming events and using the store to optimize both resources and progress.
Final Thoughts
Unlocking Extinct Matteo requires a mix of strategy, patience, and a little bit of luck. Whether you’re fusing high-tier characters or purchasing directly from the Steal a Brainrot store, having a clear plan will make the process smoother. By leveraging community resources like U4GM and staying active in events, you can add Matteo to your roster without unnecessary delays.
FrostWhisper в оффлайне Old Post 29.10.2025 22:57
Посмотреть профайл автора Click here to Send FrostWhisper a Private Message Найти еще сообщения от FrostWhisper Добавить FrostWhisper в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 09:42. Новая тема   Ответить
