Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > The Ultimate Guide to Shiny Hunting Riolu in Pokémon Legends ZA
FlameViper
На форумах с июля 2025
If you're a fan of Pokémon Legends ZA and hunting for shiny Pokémon, then you’re in for a treat with the Shiny Riolu hunt! Whether you're a seasoned player or just getting into shiny hunting, this guide will walk you through the best methods, locations, and tips to catch that elusive shiny Riolu. Get ready to level up your hunting game and improve your chances of encountering one of these rare, sparkling creatures.
Best Location for Shiny Riolu Hunting
The key to successfully finding shiny Riolu lies in knowing the best hunting grounds. Head to Blue Sector 5, which is conveniently located right across from Wild Zone 12. From here, the process begins with a simple fly to the area, where you can set up the perfect conditions for your shiny hunt.
Step-by-Step Location Guide:
Starting Point: Begin by flying to the cafe truck at Blue Sector 5. From here, look for Magikarp before heading across and taking a right.
Ice Bridge: Next, use a fire-type move to break the ice bridge and make your way to Binnacle. If you’re also hunting for a shiny Binnacle, this area is your best bet, as it spawns in the same vicinity.
Rooftop Hunt: After reaching the ladder, climb up to the rooftops. This expands your shiny hunt possibilities, as you now have access to a larger spawn area.
Riolu Spawn Point: To find Riolu, head to a park bench located near a specific spawn zone. This bench is your golden spot—take a seat, and soon, a Riolu will spawn nearby. With some patience, you could be lucky enough to encounter a shiny one!
This method offers a great way to shiny hunt Riolu, and you’ll even find other shinies such as Gastly and Pidgeot while you’re at it!
Bench Reset AFK Method
One of the most efficient ways to farm for a shiny Riolu is using the bench reset AFK method. Once you’re settled in the park bench area, you can AFK (away from keyboard) while you wait for Riolu to spawn. This method works best during sunny days, as Riolu only appears in this weather condition.
Tips for Successful AFK Hunting:
Be patient: The process may take some time. You’ll want to leave your game on for an extended period, even overnight, and let Riolu spawn naturally.
Look out for surprises: As you wait, other shinies, like Gastly and Pidgey, will likely spawn. These can be caught while waiting for the shiny Riolu to appear.
Use Macros: Some players prefer to use controller macros (like with an 8bitdo Pro controller) to automate the bench reset process.
The Active Shiny Hunting Method
If you're not a fan of AFK hunting and prefer a more active approach, there’s a quicker method to hunt shiny Riolu. This involves manually knocking out Riolu and resetting the spawn repeatedly.
Step-by-Step Active Hunting:
Knock out Riolu: Begin by engaging and knocking out Riolu, which will trigger its respawn.
Timing Your Save: Use a stopwatch to track the exact moment Riolu despawns. As soon as it disappears, save your game.
Reset for Fast Spawns: After saving, reload the game and wait for Riolu to respawn. This method is quicker than AFK hunting, but you’ll need to be active for it to work.
Bonus: Shiny Alpha Hawlucha
While hunting for Riolu, there’s a chance to encounter other shiny Pokémon in the area, including Shiny Alpha Hawlucha. As part of this method, the spawn rate for Hawlucha is fairly high (about 50% within range), meaning you could snag this rare shiny as a bonus while you’re focused on Riolu.
Special Tips for the Best Results
Time of Day: Remember that Riolu only spawns during the daytime, so make sure to hunt when the sun is shining.
Weather Conditions: If the weather suddenly changes (e.g., a rainy day), Riolu won’t spawn. If this happens, consider waiting for a new day with sunny weather.
Shiny Charm: If you’re hunting with a shiny charm, your odds of encountering a shiny Riolu (or any shiny) are significantly increased. This item is a must-have for dedicated shiny hunters.
How to Get Your Hands on Shiny or Custom Pokémon
Sometimes, players opt for a shortcut to obtaining their shiny or custom Pokémon. If you’re looking to add a shiny Riolu or other rare Pokémon to your collection without the grind, you can buy shiny Pokémon from trusted sources like U4GM. Additionally, some players choose to buy custom Pokémon tailored to their specific needs and preferences.
Shiny hunting is all about patience and persistence, and Pokémon Legends ZA offers a lot of opportunities to make that dream shiny Riolu a reality. Whether you’re using the AFK bench reset method or opting for the more active approach, the process can be both rewarding and fun. Remember to stay patient, keep your game conditions ideal, and who knows—you might even stumble upon a shiny Alpha Hawlucha along the way!
With the right strategy and a little bit of luck, you’ll be well on your way to adding shiny Riolu to your collection!
FlameViper в оффлайне Old Post 08.11.2025 06:37
Время на форуме соответствует Гринвичу . Сейчас время - 18:33. Новая тема   Ответить
