Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > Отключайка > Город Грыблия > U4GM PoE 3.27 League Starter Build Guide: Earthquake Gladiator
1fuhd
На форумах с ноября 2025
Path of Exile 3.27 brings a wave of changes that make league starts feel fresh again, and the Earthquake Gladiator is one of those builds that quietly shines from day one. It's a simple, reliable choice that leans on Earthquake for damage and the Gladiator ascendancy for a mix of offense and defense PoE 1 Currency. What makes it stand out is how comfortably it handles early game content while still having enough depth to grow into tougher maps and bosses later on.
A large part of the build's appeal is how sturdy it feels. Gladiator naturally leans into blocking attacks and spells, which helps reduce a lot of incoming hits that would punish squishier builds. Most players choose to run Iron Reflexes as well, converting evasion into armor to smooth out physical damage spikes. Paired with bleed bonuses and defensive layers from the ascendancy, the build offers a forgiving playstyle that can take hits without feeling constantly on edge.
On the offensive side, Earthquake fits surprisingly well here. Its wide area lets you clear packs with minimal effort, and the physical damage scales neatly with common passive tree nodes and affordable gear. Many players like to weave in Vaal Earthquake for bosses, since the burst damage makes tougher encounters far less stressful. Supporting gems usually focus on getting faster aftershocks or pushing the damage higher when needed, and axes tend to be the weapon of choice thanks to their strong base damage and synergy with bleed.
Leveling into the build is fairly smooth. You can use early skills like Spectral Throw or Ground Slam until Earthquake becomes available, and the passive tree offers plenty of life and defensive nodes that keep things steady through the campaign. The transition into full Earthquake gameplay happens naturally as gear improves, making it a comfortable start even for newer players or those returning after a break.
When gearing up, the priorities are straightforward: physical damage on weapons, life and resistances on armor, and enough mana sustain to avoid running dry during long fights. A good axe with strong physical damage makes a noticeable difference, and a solid shield can help round out defenses with extra block or ailment avoidance. The build doesn't demand expensive uniques early on, but you can slot them in later to squeeze out more damage or tankiness once the basic setup is in place.
One of the reasons the Earthquake Gladiator remains popular is its ability to scale into higher-tier maps without requiring perfect gear. With steady upgrades, it handles tier 16 content comfortably and can push into tier 17 without feeling like it hits a wall. Bleed mechanics, fortify, and reliable block all help keep the character alive even when surrounded, making it a dependable pick for solo self-found players or anyone who prefers a more straightforward melee approach.
The Earthquake Gladiator is a well-rounded and approachable build in PoE 3.27. It offers enough damage to keep pace with the league's challenges, enough defense to avoid constant frustration, and enough flexibility to grow with your gear PoE Currency. For players who want a smooth league start that can blossom into a strong endgame character, it remains one of the safer and more satisfying choices in the current meta.
1fuhd в оффлайне Old Post 20.11.2025 04:59
Посмотреть профайл автора Click here to Send 1fuhd a Private Message Найти еще сообщения от 1fuhd Добавить 1fuhd в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 12:42. Новая тема   Ответить
