Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > A Comprehensive Guide to the Jupiter Sniper Rifle in Arc Raiders
CoronaWave
In Arc Raiders, the Jupiter is a high-tier sniper rifle known for its exceptional damage output and accuracy. It's one of the most powerful weapons available in the game, making it a top choice for players who want to deal heavy damage from a distance. However, like any weapon, it comes with its strengths and limitations, and understanding how to use it effectively is key to maximizing its potential. In this guide, we’ll go over the important aspects of the Jupiter sniper rifle, including how to craft it, its stats, and the best ways to use it in battle.
What Makes the Jupiter Sniper Rifle Special?
The Jupiter sniper rifle stands out in Arc Raiders for several reasons. Its damage output is among the highest in the game, making it a formidable weapon, especially against tougher enemies like Bastions or Bombardiers. In general, most players use the Jupiter to take down high-health targets or to provide support from a distance. The main reasons for its popularity are:
High Damage: With a headshot multiplier of 2.0 and a damage rating of 60, the Jupiter can deliver a massive 120 damage, which is higher than most other weapons in the game. This makes it especially useful for piercing through shields and dealing with heavily armored foes.
Strong ARC Armor Penetration: The Jupiter has very strong ARC armor penetration, allowing it to pierce through enemy ARC armor and strike directly at the core. This is a game-changer when facing large, armored targets.
Accuracy and Range: It has exceptional accuracy and range, making it ideal for picking off enemies at long distances.
How Does the Jupiter Perform in Combat?
While the Jupiter’s damage is high, it’s important to understand how it performs in combat to make the most of it. The weapon operates on a bolt-action firing mode, which means you’ll need to manually reload after each shot. This slow handling can be a drawback in fast-paced combat situations. However, most players find that the high damage and accuracy make up for this slow rate of fire, especially when used strategically from a safe distance.
In practice, you’ll want to position yourself where you can take shots at enemies without getting too close. The stability of the Jupiter is also quite good, with a value of 73.5, meaning your shots are unlikely to drift significantly off target. However, its agility stat is lower (39.2), meaning you’ll move slower while using it.
Best Use Cases for the Jupiter Sniper Rifle
The Jupiter is particularly effective against medium to heavy armored targets. Its ARC Armor Penetration allows it to bypass shields and deal direct damage to the core of enemies. Here are some ideal scenarios to use the Jupiter:
Long-range Support: If your team is engaging enemies from a distance, you can use the Jupiter to provide sniper support. Its long range (71.7) makes it an excellent choice for picking off targets that are far away, without getting into the line of fire.
Taking Down Heavy Targets: The Jupiter is great for dealing with large enemies like Bastions or Bombardiers. The weapon’s damage and armor penetration make it one of the best options for taking down these tough enemies quickly.
Headshots: With a headshot multiplier of 2.0, aiming for the head will significantly increase the damage you deal. This is especially useful when fighting enemies with high health or shields, as a well-placed headshot can take them out in one shot.
However, there are some downsides. Because of the bolt-action firing mechanism, you’ll need to be patient and precise. It’s not ideal for rapid-fire situations or for when you're caught in close-quarters combat.
How to Craft the Jupiter Sniper Rifle
The Jupiter sniper rifle is a legendary weapon, which means it can’t be simply bought from vendors or found as a drop. Instead, you’ll need to craft it at the Gunsmith 3 workshop. Here's the recipe for crafting the Jupiter:
3x Magnetic Accelerator
3x Complex Gun Parts
1x Queen Reactor
Once you've gathered the materials, head to the Gunsmith 3 workshop and craft the weapon. Keep in mind that the blueprint for the Jupiter is locked, meaning you will need to unlock it through progression before you can craft it.
Repairing and Recycling the Jupiter
Like all weapons in Arc Raiders, the Jupiter sniper rifle will degrade over time as you use it. To repair the weapon, you will need the following materials:
2x Magnetic Accelerator
1x Complex Gun Parts
The durability of the Jupiter is also an important factor to consider. Each time you use it, the weapon will lose durability, which can be repaired by spending the required materials. In general, you’ll want to keep the durability up, as using a damaged weapon can lead to performance issues in combat.
Additionally, if you decide to recycle the Jupiter, you can recover some valuable materials, including:
This makes the Jupiter a relatively cost-effective weapon if you're looking to salvage materials for other crafts or repairs.
Is the Jupiter Worth It?
Whether or not the Jupiter is worth crafting depends on your playstyle and what role you want to play in your team. If you prefer long-range combat and want to be able to deal massive damage to tough enemies, then the Jupiter is an excellent choice. However, if you tend to engage in fast-paced, close-quarters combat, you might find the slow reload time and low agility a bit of a drawback.
For most players, the Jupiter’s high damage output and strong armor penetration make it a must-have in certain situations, especially when tackling larger enemies or providing sniper support to your team.
If you’re looking to sell ARC Raiders items online for real money on U4N, you’ll find that the Jupiter sniper rifle is often one of the most sought-after items due to its rarity and effectiveness in battle.
The Jupiter sniper rifle is an incredibly powerful tool in Arc Raiders, especially if you like to take on tougher enemies or provide long-range support to your team. Its high damage output, strong ARC armor penetration, and accuracy make it one of the best sniper rifles available. However, it does come with some drawbacks, such as slow handling and a bolt-action firing mode. Crafting and maintaining the Jupiter requires some investment in resources, but its effectiveness in combat makes it well worth the effort for players who enjoy long-range sniper gameplay.
CoronaWave в оффлайне Old Post 28.12.2025 22:24
Время на форуме соответствует Гринвичу . Сейчас время - 10:28. Новая тема   Ответить
