Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Игры > Path of Neo > Grow A Garden Crocodile Passive Ability and Best Uses
TheFinalBoss
What is the Crocodile in Grow A Garden?
The Crocodile is a mythical pet in Roblox Grow A Garden. It was added during the Mega Safari Harvest Event on November 8th, 2025. In general, mythical pets are meant for late-game players, and the Crocodile follows that pattern. Most players see it as a long-term investment rather than something you rush to get early.
The Crocodile is known mainly for its passive ability, Croc Roll, which can give strong bonuses to both plants and pets. Because of this, it is usually used in setups where players are focused on fast growth cycles or leveling pets more efficiently.
How do you obtain the Crocodile?
The Crocodile is obtainable through the Safari Shop. There are two ways most players get it:
800,000,000 Sheckles
699 Robux
In practice, most players who buy it with Sheckles are already deep into the game and have stable income from high-value crops. The Sheckle price is very high, so newer players usually do not consider this pet until much later.
Some players choose to use Robux instead, especially if they want the Crocodile during the event period without waiting to grind the full amount. Others save Robux for different pets or upgrades and skip it at first.
Is the Crocodile worth the cost?
Whether the Crocodile is worth it depends on how you play Grow A Garden.
In general:
If you focus on high-speed plant growth, the Crocodile can be useful.
If you focus on pet leveling, it can also help.
If you play casually or check in only once in a while, the value is lower.
Most players agree that the Crocodile is not required to progress, but it can make certain strategies more efficient once you already have a strong setup.
What does the Crocodile’s passive ability do?
The Crocodile’s passive ability is called Croc Roll.
Here is how it works in practice:
Every 10 to 20 minutes, the Crocodile targets a random plant or pet.
It bites onto that target for 30 to 50 seconds.
During this time:
Plants receive an extra 45–90 growth seconds per second.
Pets receive an extra 35–65 XP per second.
This means the effect is strong, but unpredictable. You cannot choose which plant or pet gets bitten.
Most players treat Croc Roll as a bonus rather than something they rely on precisely. Over time, the boosts add up, especially if you stay online and let the passive trigger multiple times.
How reliable is Croc Roll?
Croc Roll is occasional, not constant. In general, you should expect it to activate a few times per hour if you stay in-game.
Because the target is random:
Sometimes it hits a high-value crop and feels very rewarding.
Sometimes it hits a low-priority plant or a pet you are not actively leveling.
Most experienced players design their gardens so that any boost is still useful. That way, even a random Croc Roll is rarely wasted.
How does the Crocodile affect plant growth?
When Croc Roll targets a plant, the growth bonus is very noticeable.
In practice:
Plants mature faster.
Harvest cycles shorten slightly over time.
High-tier crops benefit more because their long growth times amplify the effect.
Most players pair the Crocodile with:
Slow-growing, high-profit plants
Gardens where multiple growth boosts are already active
The Crocodile does not replace other growth pets, but it stacks well with them.
How does the Crocodile affect pets?
When Croc Roll targets a pet, that pet gains bonus XP per second for the duration.
In general:
This is useful for leveling pets passively.
It works best when you have fewer pets equipped, increasing the chance the Crocodile hits the one you want.
Most players do not rely on Croc Roll alone to level pets. Instead, they see it as a background boost that helps over long play sessions.
What is the Crocodile’s hunger level?
The Crocodile has a hunger stat of 88,000, which is quite high.
This means:
It needs to be fed regularly to stay active.
Players who forget to feed pets may not get full value from it.
Most players who use the Crocodile seriously already have food production systems in place, so the hunger cost is manageable.
What does the Crocodile look like?
The Crocodile has a forest-green body with a tan underbelly. Along its back are darker green scales, giving it a rough, armored look. Its legs are short and stubby, ending in dark green feet.
In general, the design fits well with the Safari theme and stands out clearly in a crowded garden without being flashy.
When should you consider getting the Crocodile?
Most players consider getting the Crocodile when:
They already own several strong pets
Their garden is producing consistent high income
They spend longer sessions in-game
If you are still building your first profitable setup, the Crocodile is usually not a priority.
Some players who want faster progression during events also look into currency shortcuts. In community discussions, you may occasionally see references like buy Grow a Garden tokens for Roblox on U4N, but most experienced players recommend understanding the game’s systems first before spending resources.
Common mistakes players make with the Crocodile
Some common issues include:
Expecting Croc Roll to trigger constantly
Relying on it for targeted boosts
Forgetting to manage hunger
The Crocodile works best when treated as a passive helper rather than a core mechanic you try to control.
Final thoughts on the Crocodile
The Crocodile is a strong but situational mythical pet in Grow A Garden. It shines in late-game setups where random growth and XP boosts still provide consistent value. Most players who enjoy optimizing long play sessions appreciate what it offers, while casual players may find the cost hard to justify.
TheFinalBoss в оффлайне Old Post 29.12.2025 00:26
Время на форуме соответствует Гринвичу . Сейчас время - 21:04. Новая тема   Ответить
Оцените тему:
