Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > Understanding the Splendent Noble Dragon Lord Greatsword in Aion 2
For players of Aion 2, high-level gear can be confusing, especially weapons that come with multiple stats and mechanics. One such weapon is the Splendent Noble Dragon Lord Greatsword. This guide explains how it works in practice, what most players use it for, and how to get the most out of it.
What is the Splendent Noble Dragon Lord Greatsword?
The Splendent Noble Dragon Lord Greatsword is a Heroic-level weapon designed for Gladiators of the Elyos race. It has an item level of 114 and can be equipped at level 45, which makes it a strong choice for mid-to-high-level PvE and PvP content.
In general, most players see this weapon as a PvE-focused sword with good stats for both damage output and survivability. It comes with a Dragonheart appearance, which does not affect stats but adds a distinct visual style.
What are the main stats, and why do they matter?
Here’s a breakdown of the main stats and how they affect your gameplay:
Attack (489–661): This is the base damage of the weapon. Most players prioritize high attack because it directly increases overall damage.
Accuracy (100): Ensures that your attacks land more reliably. Gladiators usually need moderate accuracy since high-level monsters can evade.
Critical Hit (150): Increases your chance of landing a critical hit. For PvE, critical hits help clear mobs faster, while in PvP, they can determine burst damage.
PvE Damage Boost (5%): A flat boost specifically for PvE content. This is particularly useful in dungeons and raids.
Block (150): Increases defensive ability. While Gladiators are primarily damage dealers, block can help reduce damage from monsters or enemy players.
The weapon also has 5 Magic Stone slots and 1 Divine Stone engraving slot, allowing customization. Most players fill these slots with stones that increase attack or critical hit to match their preferred playstyle.
How does Soul Imprint work?
One feature of this weapon that many players value is Soul Imprint. When the weapon’s soul is initially imprinted, it grants 6 additional abilities. The stats from Soul Imprint are:
Might: 81–100
Precision: 81–100
Attack: 32–44
Accuracy: 68–85
Critical Hit: 37–50
HP: 306–359
MP: 153–183
Combat Speed: 13.8%–15.9%
Status Effect Chance: 23%–26.5%
Multi-hit Chance: 9.8%–11.3%
Critical Attack: 52–67
Back Attack: 52–67
Block: 57–73
Weapon Damage Boost: 14.9%–17.2%
In practice, this means that most players see Soul Imprint as a way to significantly boost combat stats without needing additional gear. It increases attack speed, critical damage, and survivability in one package.
How do players usually enhance the weapon?
The Splendent Noble Dragon Lord Greatsword can be:
Enchanted up to +20
Exceeded up to +5
Most players focus on reaching enchant +15 to +20, as this significantly increases attack and critical stats. Exceeding is usually reserved for long-term progression and is often applied when you have fully optimized other gear.
Additionally, using Magic Stones and Divine Stones helps tailor the weapon for PvE or PvP:
For PvE, most players prioritize stones that increase attack, PvE damage, and critical rate.
For PvP, stones that increase block, critical attack, and status effect chance are more common.
How do I get this weapon?
In general, the Splendent Noble Dragon Lord Greatsword is obtained through crafting. Players usually need:
Crafting materials from mid-to-high-level content
Some previous heroic weapons or crafting blueprints
Once crafted, the weapon can be traded, stored, enchanted, and decomposed, which gives players flexibility depending on their needs.
How does it perform in practice?
From experience, here’s how the weapon behaves in the field:
PvE: The 5% PvE damage boost and high attack make it very effective against mobs and dungeon bosses. Critical hits and multi-hit chance allow most players to clear groups efficiently.
PvP: While it can work in PvP, its strengths lean toward PvE. Gladiators usually rely on this weapon’s high attack and critical damage, but block and combat speed from Soul Imprint also help in duels.
Combat Style: Most players use a mix of standard attacks and skills. The weapon’s multi-hit and back attack stats make it ideal for burst combos and follow-up attacks on vulnerable targets.
Is this weapon worth prioritizing?
In general, the Splendent Noble Dragon Lord Greatsword is worth it if you are focused on Gladiator PvE content. Its stats are balanced, and the Soul Imprint gives a good all-around boost.
However, some players may prioritize weapons with higher PvP stats if dueling or arena play is the main goal. Usually, this weapon is a solid choice for mid-level progression, especially if you plan to enchant and customize it fully.
Key Tips for Using the Splendent Noble Dragon Lord Greatsword
Focus on enchantments first: Reaching +15 or higher gives the biggest boost in practice.
Use stones strategically: Adjust Magic and Divine Stones for your intended role—PvE farming or PvP dueling.
Apply Soul Imprint early: It provides immediate benefits and enhances combat stats without waiting for additional gear.
Balance offense and defense: While attack is important, don’t ignore block and HP if you plan to tank in group content.
Craft carefully: Materials can be costly, so ensure you have the resources to maximize your investment.
The Splendent Noble Dragon Lord Greatsword is a versatile and strong weapon for Elyos Gladiators in Aion 2. In general, players find it most effective in PvE due to its attack, PvE boost, and Soul Imprint. Proper enchantments, stone enhancements, and careful crafting make it a reliable choice for mid-level progression. While it can work in PvP, its main strength lies in helping players clear dungeons, complete quests efficiently, and maximize overall combat stats.
Many gamers buy Aion 2 items from U4N for convenience: https://www.u4n.com/aion-2/items
AmandaMartin в оффлайне Old Post 06.01.2026 00:44
Время на форуме соответствует Гринвичу . Сейчас время - 12:52. Новая тема   Ответить
