Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > How to Find the Extended Shotgun Mag III Blueprint in Arc Raiders
CoronaWave
If you’ve been playing Arc Raiders and want to upgrade your shotgun, one of the key items you’ll need is the Extended Shotgun Mag III Blueprint. Many players wonder where to find it, how to use it, and what’s required to craft the actual magazine. This guide is written from the perspective of someone who’s spent a fair amount of time playing and testing different strategies, so it focuses on practical answers rather than marketing language.
What Is the Extended Shotgun Mag III Blueprint?
In general, a blueprint in Arc Raiders is an item that lets you craft a specific upgrade or equipment piece. The Extended Shotgun Mag III Blueprint specifically allows you to craft the Extended Shotgun Mag III, which increases your shotgun’s magazine size.
Most players consider this blueprint useful if you rely on shotguns for crowd control or close-range combat because it reduces the number of reloads needed during missions.
Where Can I Find the Extended Shotgun Mag III Blueprint?
Most players get this blueprint by looting in the topside areas of the map. In practice, “topside” usually refers to the upper zones of a mission map or elevated platforms where loot is more common but also riskier because of enemy density.
From experience, you should:
Check high-traffic loot zones first. Other players often prioritize these spots, so expect some competition.
Pay attention to loot rarity indicators; the blueprint is generally not guaranteed on every run. Looting multiple times or farming certain areas may be necessary.
Carry gear that allows fast movement and survival; the topside areas can have multiple enemy encounters in quick succession.
In general, finding this blueprint is a mix of persistence and knowing which areas tend to spawn high-tier loot.
How Do You Craft the Extended Shotgun Mag III?
Once you have the blueprint, crafting it is fairly straightforward. The requirements are clear, but there are some practical considerations:
Requirements:
Gunsmith 3 (skill level)
2x Mod Components
5x Steel Springs
Most players note that while the blueprint itself is rare, the materials are usually farmable during normal gameplay:
Mod Components are typically found from dismantling lower-tier mods or salvaging enemy equipment. It’s often faster to gather them in bulk if you plan to craft multiple items.
Steel Springs are usually found in industrial or mechanical zones of missions. Keep an eye out for containers marked as mechanical or supply crates.
Skill Level (Gunsmith 3):
In general, Gunsmith 3 is not extremely hard to reach, but it requires some investment in crafting and weapon upgrade skills. Most players will hit this skill level naturally after progressing through the early game.
Once you have the materials and skill level, crafting is just a matter of using the blueprint at your crafting station. There’s usually no random chance of failure, so the output is guaranteed if all requirements are met.
How Effective Is the Extended Shotgun Mag III in Practice?
Many players focus on the raw stats, but in practical terms:
It significantly reduces reload interruptions during missions. This is particularly useful in fights against multiple enemies or during timed objectives.
Most players combine it with high-damage or high-rate-of-fire shotguns. It doesn’t increase damage directly but improves sustained fire.
It is generally considered a mid- to late-game upgrade. Early on, you can usually manage with standard magazines, but once you face higher-tier enemies, the extended magazine becomes noticeably more convenient.
A common approach is to prioritize extended mags for shotguns over rifles in early PvE missions because shotguns tend to run out of ammo faster due to high spread and rate of fire.
Tips for Using the Blueprint and Crafting Effectively
Farm Materials in Bulk: Players often underestimate the number of Mod Components and Steel Springs needed for multiple upgrades. Collecting extra while farming enemies or loot chests saves time later.
Check Topsides Frequently: Since the blueprint spawns randomly in topside areas, checking each run increases your chances. Some players even create dedicated farming routes.
Upgrade Gunsmith Skills Early: Reaching Gunsmith 3 early gives you flexibility to craft more advanced mods without waiting for additional skill points.
Combine With Ammo Management: Extended magazines are most effective when paired with ammo-efficient strategies. Avoid wasting shotgun rounds on distant targets to get the most out of the upgrade.
Plan Your Loadout Around Reloads: Players who rely heavily on shotguns often pair the Extended Shotgun Mag III with skills or perks that reduce reload times, maximizing uptime in combat.
Common Player Questions
Q: Can I get multiple copies of the blueprint?
Usually yes, but in practice, most players only need one copy. Once crafted, the item itself is reusable if you craft additional magazines. Extra blueprints are mostly for trading or backup if the game supports that.
Q: Does it work on all shotguns?
Yes, but most players use it on mid- to high-tier shotguns. Low-tier weapons may not justify the resource cost for upgrades.
Q: Is crafting the magazine expensive?
Not really. While the materials aren’t completely trivial to gather, they’re relatively common for players who farm regularly. The main constraint is having Gunsmith 3.
The Extended Shotgun Mag III Blueprint is a practical upgrade for players who rely on shotguns. You find it by looting topside areas, craft it using gunsmith skills and materials you can farm in missions, and it improves your sustained fire in combat. In general, the blueprint is more about convenience and efficiency than raw power, but it becomes noticeably valuable in tougher missions where reloading can slow you down.
Most players treat it as a mid-game priority for shotgun loadouts, combining it with other upgrades and careful ammo management to maximize its benefit. The key to success is knowing where to find the blueprint, farming materials efficiently, and integrating the upgrade into your overall combat strategy.
U4N is a good platform for ARC Raiders gear: https://www.u4n.com/arc-raiders/items
CoronaWave в оффлайне Old Post 08.01.2026 03:54
Время на форуме соответствует Гринвичу . Сейчас время - 14:53. Новая тема   Ответить
