Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > Aion 2 Skill Level Up – Mocking Blade
What is Mocking Blade?
Mocking Blade is a skill that falls under the Epic tier in Aion 2. Once leveled, it increases your combat capabilities by adding more damage or utility depending on your class setup. Unlike basic skills you get automatically, Epic skills like Mocking Blade require Daevanion Points to unlock and level up, which makes planning your skill tree crucial.
In practice, many players prioritize this skill if their build focuses on burst damage and crowd control. The skill becomes available at level 30, so you need to reach that before considering the point investment.
How Do You Level Up Mocking Blade?
The skill is leveled through the Daevanion Node system. Here’s the practical breakdown:
Required Level: 30
Cost: 3 Daevanion Points per level
Effect: +1 level to the skill per upgrade
To level up Mocking Blade, you navigate to your skill tree, locate the node at Row 11, Column 9, and spend the necessary Daevanion Points. Each upgrade will increment the skill by one level. In practice, most players aim to max it as soon as possible because the early levels provide the most noticeable improvements.
How Do Daevanion Points Work?
Daevanion Points are earned through normal gameplay—mainly from quests, dungeon runs, and world events. Efficient players often track their points and plan ahead. You don’t want to waste points on skills you won’t actively use.
A tip for players who may not have enough points is that you can sometimes supplement progress by purchasing resources from the marketplace. Many players choose to buy Aion 2 gold to accelerate access to items or services that indirectly save Daevanion Points, which allows faster skill upgrades without extra grinding.
Practical Tips for Leveling Skills
Plan Your Node Path:
Before spending points, check which skills complement your class build. Mocking Blade is best for DPS-focused characters, so if your build is support-oriented, you might want to prioritize other nodes first.
Don’t Overcommit Early:
The first few levels of Mocking Blade give a noticeable boost, but later levels provide diminishing returns. Spend points where you get the best immediate effect.
Combine with Gear:
Upgrading the skill alone is effective, but pairing it with gear that enhances attack speed or critical rate can significantly boost performance.
Check the Cost vs Benefit:
Every level costs 3 Daevanion Points. If you’re saving points for other high-impact skills, weigh whether Mocking Blade is worth the investment at that moment.
How Does Mocking Blade Perform in Practice?
From my experience and observation of other players, here’s how the skill behaves during actual gameplay:
Early Levels: Adds minor damage and slightly reduces enemy defenses, which is noticeable in dungeon mobs.
Mid Levels: The skill begins to synergize with other abilities, allowing for combos and faster enemy takedowns.
Max Level: Fully upgraded, it becomes a reliable part of your rotation for PvE and PvP encounters. Timing and positioning matter; it’s most effective when used after crowd control effects or in combination with buffs.
Players often report that Mocking Blade feels underwhelming if isolated. Its true value shows when used strategically within a combo or a coordinated party setup.
Common Questions About Mocking Blade
Q: Can I unlock this skill before level 30?
No. The skill node has a hard requirement of level 30, so your character must reach that point first.
Q: Is it better to max Mocking Blade first or other Epic skills?
It depends on your build. DPS builds benefit from leveling it early, while tank or healer builds might find other skills more effective. A balanced approach is usually best.
Q: Are there alternatives if I don’t have enough Daevanion Points?
You can focus on lower-tier skills temporarily, participate in events to earn more points, or explore ways to supplement resources, such as trading or buying in-game currency. Many players buy Aion 2 gold to cover gaps when resources are tight, especially for premium items or essential upgrades.
Q: Does skill level affect PvP significantly?
Yes. Higher skill levels improve damage output and effect duration, which can make a difference in duels or group fights. However, timing and strategy are often more important than maxing the skill alone.
Mocking Blade is a solid Epic skill that rewards careful planning and strategic investment. Key points to remember:
Available at level 30, costing 3 Daevanion Points per level
Early upgrades provide the biggest noticeable impact
Best used as part of a DPS or hybrid DPS-support build
Synergizes with gear and other abilities
Consider resource management—sometimes supplementing progress by purchasing gold is a practical choice
By understanding the mechanics, cost, and optimal use, you can make informed decisions about when and how to level up Mocking Blade. Keep an eye on your Daevanion Points and skill tree priorities, and you’ll get the most out of this skill in both PvE and PvP scenarios.
AmandaMartin в оффлайне Old Post 23.01.2026 03:04
Время на форуме соответствует Гринвичу . Сейчас время - 07:42. Новая тема   Ответить
