Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > How to Use the Fireball Burner for Efficient Kills in Arc Raiders
CoronaWave
What is the Fireball Burner?
The Fireball Burner is an uncommon item in Arc Raiders. It is primarily used to create small fires on the ground, which deal damage to any players or enemies within a 2-meter radius. The fire lasts for about 10 seconds, making it useful for crowd control and strategic area denial. In addition to its basic utility, the Fireball Burner can be recycled into ARC Alloy, a valuable resource for crafting other items.
Key Stats of the Fireball Burner:
Damage: 5 damage per second (s)
Duration: 10 seconds
Radius: 2 meters
Sell Price: 640 Coins
How to Acquire the Fireball Burner?
You can find Fireball Burners in a few ways:
Scavenging in ARC (specifically from sources like Fireball and Courier)
ARC Raiders item U4N shop sometimes offers them for purchase, depending on availability.
How to Use the Fireball Burner for Killing Enemies?
The Fireball Burner’s primary utility in combat is as a throwable item. Here’s how it works in practice:
Throwing and Timing: When you throw the Fireball Burner, it will land at the targeted location and ignite a fire. The fire deals continuous damage to all enemies or players within its 2-meter radius. The key to using it effectively is timing your throw. If you’re engaging a group of enemies, throwing it at their feet or in a choke point can inflict steady damage, forcing them to either move or take damage over time.
Strategic Use in Combat:
Area Denial: If you find yourself cornered or need to control enemy movement, you can throw the Fireball Burner to block key paths or entrances. This tactic works well in narrow spaces or when defending objectives.
Damage Over Time: The fire lasts for 10 seconds, so any enemies standing in the fire’s radius will continue to take damage. If you’re engaging enemies with high health, or if they’re distracted by other threats, this damage over time can add up.
Against Groups: The Fireball Burner is especially effective when you’re facing multiple enemies. Since the fire deals area-of-effect damage, it’s excellent for crowd control. Throw it into the middle of a group, and enemies will either be forced to move or take damage from the fire.
Combo Attacks: You can combine the Fireball Burner with other abilities or items to increase its effectiveness. For example, using it in conjunction with a stun grenade or another crowd control ability can keep enemies trapped in the fire’s radius, maximizing your damage output.
Can the Fireball Burner be Used to Kill Players?
Yes, the Fireball Burner can also damage players in PvP situations. It can be used to flush out enemies hiding behind cover or force them to retreat from key objectives. While it won’t necessarily kill a player outright, the damage over time can add up, especially if they’re already weakened from previous encounters.
Be mindful, though—players can dodge or avoid the fire if they’re quick enough, so it’s best used in combination with other strategies to ensure success.
What Happens if the Fireball Burner Breaks?
After you throw a Fireball Burner, it may break or become damaged. A Damaged Fireball Burner can be salvaged or recycled, so it’s not a total loss. While a damaged version won’t deal as much damage or have the same effectiveness, it can still be used for crafting or as part of the refining process in your base.
How to Repair the Fireball Burner?
You can repair a damaged Fireball Burner by combining it with a Canister. This repair process will give you back a fully functional Fireball Burner that you can throw again. Repairing items like this is a useful way to keep your resources running efficiently without needing to scavenge for new ones.
Is the Fireball Burner Useful in Solo or Team Play?
Solo Play: The Fireball Burner is very effective in solo play, especially when exploring or facing off against NPC enemies. You can use it to control the battlefield, dealing damage to enemies and keeping them at a distance.
Team Play: In team play, the Fireball Burner can be an excellent tool for supporting your teammates. You can throw it to keep enemies distracted or forced into certain areas, helping your team push forward or control objectives more easily.
What Else Can the Fireball Burner Be Used For?
Aside from combat, the Fireball Burner has utility in crafting and upgrading. Here's how it fits into the broader game mechanics:
Crafting:
You can use the Fireball Burner in In-Round Crafting to create a Flame Spray, which has its own specific uses in gameplay.
Upgrades:
Fireball Burners are also used in upgrading the Refiner. To upgrade from Refiner 1 to Refiner 2, you need 8 Fireball Burners along with other components like Toasters and ARC Motion Cores.
Recycling and Salvaging:
When you’re done using a Fireball Burner, it can be recycled into ARC Alloy and Chemicals, or salvaged for ARC Alloy. This makes it a valuable resource for other upgrades and crafting processes.
How Does the Fireball Burner Compare to Other Items?
While the Fireball Burner is useful, there are other items in Arc Raiders that can offer more specialized or stronger effects, depending on your playstyle. For example:
Grenades or Explosive Items can deal more immediate damage in a single burst, whereas the Fireball Burner’s fire spreads damage over time.
Stun Grenades and Area Denial items are also useful in a similar way, but they serve a different purpose by disabling enemies rather than dealing continuous damage.
Ultimately, it’s about what fits best with your strategy and the situation you’re in.
The Fireball Burner in Arc Raiders is an essential tool for both combat and strategy. It’s best used in tight spots or when dealing with multiple enemies. Its damage over time and area effect make it a strong choice for controlling the battlefield and gaining an edge over your opponents. Whether you're playing solo or in a team, understanding how and when to use the Fireball Burner can greatly improve your chances of survival and success in Arc Raiders.
Insider Look: Arc Raiders Light Impact Grenade: How to get & best use
CoronaWave в оффлайне Old Post 23.01.2026 22:25
Время на форуме соответствует Гринвичу . Сейчас время - 17:51. Новая тема   Ответить
