Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > How to Turn Difficult Double Plays in MLB The Show 26
Double plays are one of the most satisfying plays in MLB The Show 26, but they can also be tricky to execute, especially when the situations are tense or the balls are hit hard. Knowing how to turn them effectively will help you get crucial outs and prevent runners from advancing. In this guide, I’ll walk you through the techniques and strategies that will improve your double play game.
What Makes Double Plays Difficult in MLB The Show 26?
Double plays can be tough for a few reasons. First, timing is crucial. You need to be quick and precise, especially with a runner charging down the line. Secondly, the throw animations vary depending on the fielder’s position, speed, and skill level. Mistakes with button inputs or mechanics can lead to errors or failed double plays. Finally, certain types of hits (like hard grounders or slow rollers) require different approaches, so flexibility is key.
Let’s break down how to handle these tough plays and turn them into routine outs.
How Do I Set Up for a Double Play?
The first thing to keep in mind is that you have to position your fielders well. When you're playing defense, always make sure your infielders are aligned to cover the most likely areas where a double play might occur. In MLB The Show 26, your fielder’s positioning is vital. A poor setup can prevent you from reaching the base quickly enough, causing delays in the play.
If you're facing a right-handed batter with a runner on first, for example, expect more ground balls to be hit to the right side of the field. If the batter is a lefty, ground balls tend to favor the left side more often. Adjust your shortstop and second baseman accordingly.
How Do I Turn the Double Play After Fielding the Ball?
Once the ball is hit and you've fielded it, it's time to make the throw. Here's the step-by-step breakdown:
Field the Ball Cleanly: Ensure you position your fielder well and use the right stick to get a good fielding animation. For example, you don’t want to rush your fielder into a throw before he has the ball securely in his glove. You can use the left stick to adjust your fielder’s positioning and angle before throwing.
Throw to the First Base: For the first part of the double play, after fielding the ball, quickly aim your throw to second base. To make this fast, use the R2 button for a quick throw instead of holding down the standard button, which might take longer.
Use the Double Play Button (if available): MLB The Show 26 has an option to double-tap the throw button (usually Square or Circle on PlayStation, or X on Xbox). This makes it easier for the game to recognize you want to perform a double play, especially in tough situations.
Don't Rush the Second Throw: After getting the ball to second base, the second baseman will need to catch it cleanly and throw it to first. The critical part here is timing. If you're throwing it too early or too late, the runner at first might beat the throw. Watch the runner’s speed and the animation of your second baseman to gauge the best time to release the throw.
Get the Right Angle: Always make sure your second baseman is lined up with first base before releasing the throw. If he’s too far off to the side or facing away from the base, the game might not register the throw as accurate, leading to a failed double play attempt.
How Can I Improve My Double Play Timing?
Timing is one of the most critical factors in turning double plays. A few key tips can help you refine your timing:
Don’t Overcomplicate Your Inputs: When you’re in a double play situation, simplify your button presses. Instead of trying to do too much with the analog sticks or buttons, focus on fielding and throwing with precision. The game is built to recognize your inputs, so as long as you press the right buttons at the right time, you’ll get the result you want.
Anticipate the Speed of the Ball: If a slow roller or hard-hit ground ball is coming, the way you handle the ball will change. For slow rollers, make sure you’re charging the ball instead of waiting for it to come to you, as that extra step could be crucial. With hard-hit balls, don’t be afraid to use the power throw if needed, but be careful not to overthrow.
Watch the Runner’s Speed: You can usually gauge a runner’s speed based on the base he’s occupying. A runner on first base is often slower, while a runner on second base might be faster. Knowing this will help you decide whether you need to rush the double play or if you have more time to set up.
Are There Any Tricks to Help With Double Plays in MLB The Show 26?
Here are a couple of advanced tricks that experienced players use to turn double plays:
Use the Pivot and Throw Option: For double plays involving a quick transition, like from shortstop to second base, use the R1 (or RB on Xbox) button to perform a pivot throw. This lets your fielder quickly turn and throw in one smooth motion. If you’re playing as the shortstop and need to make a quick transfer to second base, mastering this technique will save you valuable time.
Consider the Type of Pitch: The type of pitch being thrown plays a role in double play success. A fastball or a curveball with good movement can result in a harder hit ball or a slower roller. You can adjust your positioning or fielding approach based on how well the pitch is likely to be hit.
Practice Manual Fielding: While automatic fielding works in most cases, manual fielding gives you more control over your actions. By using the right analog stick for your fielder’s positioning and aiming your throws precisely, you can avoid some of the random errors that happen with automatic fielding.
What If I Can't Turn the Double Play?
It’s important to realize that not every ground ball situation is ideal for a double play. If the ball is hit too hard or too slow, or if you’re playing on higher difficulty levels, it may be too difficult to turn two. If you’re struggling, try focusing on the first out. Don't sacrifice the first out at second base for a chance to get the second out at first if you think it’s too risky. Sometimes getting one out is just as important.
Additionally, if you're looking to enhance your team's ability to turn double plays, consider upgrading the defensive stats of your infielders. Higher Fielding and Reaction ratings can make a significant difference.
Turning difficult double plays in MLB The Show 26 is all about timing, positioning, and understanding how the game mechanics work in practice. By fielding cleanly, reacting quickly, and making accurate throws, you can consistently turn two and keep runners off the base paths.
For players looking to get an edge on their competition, practicing these double play techniques in different game modes will help solidify your skills. If you’re looking for a way to enhance your game even further, check out the best site to buy MLB 26 stubs. This can give you the resources to acquire better players for your team, helping you become even more efficient at turning double plays.
AmandaMartin в оффлайне Old Post 29.01.2026 23:42
tannurawat
На форумах с января 2026
Choosing the right agency makes a big difference when you want safe and well-managed service. We focus on honesty, privacy, and proper communication. Our Escorts Service in Tilak Nagar is arranged carefully so customers do not face delay or confusion. From the first call to the final confirmation, our team stays available to help and guide every client.
tannurawat в оффлайне Old Post 26.03.2026 03:52
Посмотреть профайл автора Click here to Send tannurawat a Private Message Найти еще сообщения от tannurawat Добавить tannurawat в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 11:53. Новая тема   Ответить
