Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > How to Locate Pitches Better in MLB The Show 26
FlameViper
На форумах с июля 2025
1. Understanding Pitch Locations
Before we dive into the specific techniques for locating pitches, it’s important to understand the concept of pitch locations in the game. Every pitch in MLB The Show 26 has a designated area where it can land, often marked by a small square or grid on the screen. This grid represents the strike zone, and pitches can land in various parts of this zone, outside of it, or even in the dirt.
In MLB The Show 26, the pitch's movement, speed, and type affect how well it stays within its intended location. For example, a fastball is easier to control than a curveball, which has more movement.
2. Pitcher Control and Player Skill
For pitchers, controlling your pitch location starts with the fundamentals of pitching mechanics. In MLB The Show 26, you’re given different pitch types (like fastballs, sliders, or changeups) with varying levels of control. Some pitches have a higher degree of accuracy, while others may have more movement but less control.
Here’s how you can work on improving your pitch location:
a) Use the Right Analog Input
When you're pitching, using the right analog stick to aim your pitch is key. Aim for specific parts of the strike zone or aim just outside it to try and throw a pitch that forces the batter to chase.
It’s essential to understand that the farther your aim is from the center of the strike zone, the harder it will be to hit your target. Aim for the corners of the plate, not the middle, to force batters into uncomfortable situations.
b) Maximize Pitcher Confidence
In MLB The Show 26, pitcher confidence plays a role in how well your pitches land. The more confident your pitcher is, the more precise their pitches will be. Keeping a good rhythm and not allowing too many hits or walks will help keep your confidence high. On the flip side, allowing runs or walking batters will lower your confidence and make it harder to locate pitches precisely.
c) Use Pitching Sliders for Better Precision
If you're struggling with hitting your targets, try using pitching sliders. These can help you fine-tune your accuracy, especially when you're getting frustrated with throwing too many wild pitches. Adjusting sliders can give you an edge, making it easier to hit the spots you want.
3. Recognizing Pitch Types and Movement
One of the most effective ways to better locate pitches is by understanding how different pitches behave. Pitch types come with their own unique movement patterns, and recognizing this early on will allow you to adjust your approach.
a) Fastball vs. Breaking Pitches
Fastballs are often the easiest to locate because they have a direct, straight path. Focus on throwing fastballs in the upper or lower corners of the strike zone to get swings and misses.
Breaking balls (curveballs, sliders, and sliders) can be trickier to locate due to their movement. These pitches often start in the strike zone before breaking outside or into the batter. When throwing breaking balls, try to aim for the edges of the strike zone and use the pitch’s movement to your advantage.
b) Changeups and Off-Speed Pitches
Changeups are slower than fastballs and can fool batters into swinging too early. These pitches typically have less movement than breaking balls but can be harder to locate consistently. If you can locate your changeups low in the zone, you can make batters look foolish as they swing for a pitch that’s slower than expected.
c) Watch Your Pitcher's Stamina
A pitcher’s stamina affects how well they can control their pitches. As your pitcher’s stamina decreases, their accuracy may drop as well, which means their pitches could end up in spots you didn't intend. If your pitcher’s stamina is low, it might be worth considering pulling them or resting them between innings to ensure better pitch control.
4. Adapting to Batters’ Tendencies
To improve pitch location, it's important to adapt your strategy based on the batter’s strengths and weaknesses. Each batter in MLB The Show 26 has their own batting tendencies. Some batters struggle with high fastballs, while others may have trouble with off-speed pitches low in the zone. Knowing these tendencies can help you locate pitches where they are most likely to fail.
a) Mix Up Your Pitch Types
Don’t just rely on one pitch. A good pitcher will mix up pitch types to keep the batter guessing. If you continuously throw fastballs down the middle, hitters will adjust and start hitting more effectively. Instead, alternate between fastballs, breaking balls, and off-speed pitches to confuse the batter.
b) Pitch Inside and Outside
To keep the batter from becoming comfortable, throw pitches inside and outside the plate. This makes the batter uncomfortable, forcing them to swing at pitches they’re not used to handling. When locating pitches, try to throw on the inside corner of the plate, then switch to the outside corner on the next pitch.
5. Using the Strike Zone and the Pitching Meter
In MLB The Show 26, the strike zone is visualized on the screen, which makes it easier to aim your pitches. When you throw the ball, a meter fills up as you press the button or move the analog stick. Timing the meter properly is key to hitting your target location. If the meter is too early or too late, your pitch may miss the target.
a) Timing is Key
Each pitch has a specific meter timing that’s unique to its type. Fastballs typically have a faster meter, while off-speed pitches like curveballs may have a slower meter. If you’re struggling with pitch control, practice timing your meter to ensure better accuracy.
b) Pitching Confidence and Strategy
Keep in mind the effects of pitch confidence on your control. When you’re ahead in the count (such as 0-2), pitchers tend to throw more confidently, and their pitches are easier to locate. On the other hand, when you’re behind in the count, batters have the upper hand, and it’s much harder to get the pitch right. Focus on staying ahead in the count and using your pitcher's strengths to your advantage.
6. When You Miss, Learn From It
Finally, remember that even the best pitchers miss their spots. If you throw a pitch that doesn’t land where you intended, pay attention to what happened. Did your pitcher’s stamina affect the accuracy? Was the timing off? The best way to improve is to learn from your mistakes and adjust accordingly.
Locating pitches in MLB The Show 26 takes practice and an understanding of how pitch types work, as well as your pitcher’s capabilities. Whether you're controlling the pitcher or trying to hit, using the strike zone, mixing pitches, and understanding the batter’s tendencies can help you locate pitches more effectively.
Remember, whether you’re new to the game or a seasoned player, practice makes perfect. If you’re looking to boost your in-game experience even further, you might want to check out the best site to buy MLB 26 stubs to enhance your progress.
FlameViper в оффлайне Old Post 09.02.2026 23:50
Время на форуме соответствует Гринвичу . Сейчас время - 01:20. Новая тема   Ответить
