Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > Controlling Relay Throws in MLB The Show 26
One of the more complex parts of MLB The Show 26 is mastering the relay throw mechanics. It can make a big difference in preventing runs and ensuring your outfielders or infielders are as efficient as possible. This article breaks down how relay throws work in the game, why they matter, and how you can improve them.
What Are Relay Throws in MLB The Show 26?
In MLB The Show 26, a relay throw is when a fielder (typically in the outfield) throws the ball to an infielder, who then makes the final throw to the base or home plate to attempt a play. This is commonly used when a ball is hit deep into the outfield, and the runner on base is attempting to advance to the next base or home plate.
The goal of a relay throw is to cover as much ground as possible and ensure the throw reaches the right target with enough accuracy and speed to make the play.
Why Are Relay Throws Important?
Relay throws are crucial in high-pressure moments. Without a solid relay strategy, you may miss out on turning a double play or preventing a run from scoring. For instance, if you’re trying to cut down a runner at home plate, a well-executed relay throw from the outfield to the shortstop or second baseman can make all the difference.
In MLB The Show 26, the accuracy and timing of these throws are often the deciding factors in getting the out. Players who struggle with relay throws might find themselves losing valuable runs or letting opponents steal bases when they shouldn't.
How Do Relay Throws Work in MLB The Show 26?
To understand how relay throws work, it's helpful to know the basic mechanics behind them:
The Outfield Throw – When a ball is hit into the outfield, the player controlling the outfielder needs to decide how to throw the ball. In general, you should always aim for the cutoff man, who is either the shortstop or second baseman.
The Cutoff Man – If you’re playing in the outfield, the cutoff man will automatically position themselves in line with your throw. The key here is knowing when to make the throw to the cutoff man. If the throw is made too early or too late, the ball might be misdirected or too slow to make a play.
The Relay from the Infielder – After the cutoff man catches the ball, they will then make the final throw to either home plate or a base. The success of this relay depends on your timing and positioning.
How to Perform a Relay Throw in MLB The Show 26
To perform a relay throw, follow these steps:
Outfielder’s First Throw:
From the outfield, hold the button for the throw (usually the Square button on PlayStation or X on Xbox) to begin the throw.
Release the button when you’re ready to send the ball to the cutoff man.
Cutoff Man’s Positioning:
After the outfielder releases the ball, the cutoff man will automatically move into position, but you need to adjust slightly if needed. Use the left stick to fine-tune the cutoff man’s position.
Final Throw to the Target:
After the cutoff man catches the ball, they will either attempt to throw it home or to a base. You can use the throw button again to make this final throw, but it’s essential to aim carefully. Don’t just throw blindly; instead, focus on where the play is happening (home plate, second base, etc.).
Using the Right Stick for Throwing Power:
To add power to the throw, you can flick the right stick toward your target. The more precise your stick movement, the more accurate and powerful the throw will be.
How to Improve Your Relay Throw Accuracy
Accuracy and timing are essential when it comes to relay throws. Here are some tips for improving both:
Know the Target Location: Be aware of where the play is happening, especially when throwing to home plate. If you aim for the wrong base or plate, your throw will miss the target and could give the runner a free pass.
Timing is Key: The timing of your throws is often the deciding factor. If you release the button too early or too late, you might miss your target. Try to adjust your timing based on the situation and the speed of the runner.
Use Throwing Meter: The throwing meter that appears when making a throw shows you the strength and accuracy of the throw. Keep an eye on this meter to ensure you’re putting enough power into your throw without overdoing it.
Throwing Velocity: A powerful throw helps you reach your target faster, but don’t sacrifice accuracy for speed. It’s better to make an accurate, slower throw than to throw too hard and miss your target entirely.
Positioning and Angles: Your positioning as the outfielder and the cutoff man can also affect the relay throw. Try to stay aligned with your target and ensure you’re not throwing from awkward angles, which can lead to wild throws.
Common Mistakes to Avoid in Relay Throws
Throwing Too Early or Too Late:
A common mistake players make is throwing to the cutoff man too early or too late. This messes up the timing of the relay and can result in missed opportunities.
Missed Cutoff:
If you fail to hit the cutoff man with your throw, the ball might end up being thrown to the wrong place, or you could lose precious time.
Incorrect Targeting:
Always make sure you’re aiming at the right target. For instance, if you’re throwing home, make sure your cut-off man has the ball and you’re not accidentally throwing to third base instead.
How to Use Relay Throws to Your Advantage
In MLB The Show 26, mastering the relay throw can help you control the game more effectively. Here’s how to use relay throws to your advantage:
Preventing Extra Bases:
A well-executed relay throw can help you prevent a runner from reaching second base on a double or third base on a single. It’s critical for getting your defense back in the game quickly.
Cutting Down Runners at Home Plate:
In situations where the opponent is trying to score, a solid relay from the outfield to home plate can easily stop them. Always position your cutoff man and infielder accordingly to ensure the throw reaches home plate in time.
Efficient Fielding in Practice:
If you’re playing in Exhibition or Franchise mode, take time to practice relay throws. The more you practice, the better your instincts will be when it counts in real games.
Can You Buy Relay Throw Upgrades?
In MLB The Show 26, if you’re looking to improve your player’s throwing stats, you can visit the MLB The Show 26 stubs store to purchase upgrades. This can help your players throw more accurately and with greater velocity, which can improve relay throw performance.
Mastering relay throws in MLB The Show 26 is an essential skill for any player who wants to improve their defense. Whether you're trying to prevent a runner from advancing or trying to stop a run from scoring, a successful relay throw can make all the difference. Practice your timing, positioning, and accuracy, and you’ll be able to execute relay throws with confidence. Keep in mind that perfecting these throws takes time, but once you’ve got them down, your defense will be much stronger.
AmandaMartin в оффлайне Old Post 28.02.2026 03:45
Время на форуме соответствует Гринвичу . Сейчас время - 09:04. Новая тема   Ответить
