Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > IWC replica watches
yokwoli
На форумах с декабря 2023
IWC replica watches
IWC Reinterprets the Portuguese Chronograph with Ceratanium
A classic black version, highly recommended by Ed Sheeran.high quality replica watches
As one of the most enduring models in IWC's catalog, the Portuguese Chronograph boasts a simple, distinctive design and well-proportioned form. Now, it receives a surprising new interpretation – the Portuguese Chronograph Ceratanium, which was first unveiled during musician Ed Sheeran's Australian tour.
The Portuguese Chronograph has now evolved to its second generation, featuring an in-house movement and a clean, streamlined appearance. The vertically arranged subdials and slim, large case are particularly impressive. Previously only available in gold or stainless steel, the case is now made of Ceratanium®, a specially treated titanium metal coated with a durable ceramic layer.replica luxury watches
Unfortunately, IWC doesn't release many new watches these days, but the Portuguese Chronograph Ceratanium stands out. While essentially a simple aesthetic update to a classic model, it remains incredibly appealing.
I've always loved the Portuguese Chronograph; I love its proportions and design. Although the design is over 30 years old, it still feels fresh. The Ceratanium version is a bit special, but very appealing. The all-black case might seem out of place with the classic style, but somehow it harmonizes surprisingly well, complementing the minimalist aesthetic.https://www.reviewluxurystore.com
While the new Portuguese watch is undeniably attractive, it comes at a hefty price. It's 50% more expensive than the steel version, a premium that seems excessive even considering the superior performance of Ceratanium. This is especially true considering the Portuguese Chronograph has historically been the brand's entry-level chronograph. Frankly, all IWC Ceratanium models are quite expensive (arguably making them all seem overpriced).
Ceramic Titanium: The case size is the same as the standard model, but all components, including the pushers and crown, are made of Ceratanium. This material, previously only used in their Pilot's luxury replica watches collection, is actually a titanium alloy that is sintered at high temperatures to create a titanium oxide coating, giving the case its matte black appearance. This coating gives the case enhanced scratch resistance, but like all such coatings, it can still be damaged by sufficiently large impacts or abrasion.
The dial is in a grey tone. While not the most legible, the overall effect is quite good. The dial itself is black, while the numerals and hands are in a dark grey glossy finish, and the subdials are decorated with a concentric circle texture, giving them a lighter grey appearance. All printed text on the dial and subdials is also dark grey. Replica Breitling Chronomat
The Ceratanium model is mechanically identical to the regular production version, and therefore houses the 69355 movement. The movement is located beneath a grey sapphire crystal window, thus appearing dark on the surface, but this is not actually a change.
The 69355 movement, developed by IWC, was intended to replace the ETA Valjoux 7750 movement used in the first generation of Portuguese chronographs. It is similar in size and power reserve to the Valjoux 7750, but features significant structural upgrades. The 69355 caliber movement features numerous improvements, including a column wheel, direct-drive seconds hand, LIGA escapement, and a "magic lever" winding mechanism. replica Patek Philippe Complications
IWC Portuguese Chronograph Ceratanium Movement, Model IW371631
Case Diameter: 41 mm;
Thickness: 13.1 mm;
Crystal: Sapphire crystal;
Material: Ceratan alloy;
Water Resistance: 30 meters
Movement: Cal. 69355
Functions: Hours, minutes, seconds, and chronograph
Frequency: 28,800 vibrations per hour (4 Hz)
Winding Method: Automatic
Power Reserve: 46 hours
Strap: Rubber with Ceratanium pin buckle
yokwoli в оффлайне Old Post 02.03.2026 04:02
Посмотреть профайл автора Click here to Send yokwoli a Private Message Домашняя страница yokwoli Найти еще сообщения от yokwoli Добавить yokwoli в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
