Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > SEVENFRIDAY replica watches
yokwoli
На форумах с декабря 2023
SevenFriday PG/01 GMT high quality replica watches
While SevenFriday is known for its futuristic and visually complex style, it has historically produced relatively simple, purely hour-hand watches. However, in its 2025 new product launch, the Zurich-based brand introduced its first watch with a GMT function. This new timepiece not only features a pilot's GMT function and date display, but the SevenFriday PG/01 GMT is also arguably one of the most minimalist designs the brand has produced in recent years.
Now, when I use "minimalist" to describe the PG/01 GMT, it's important to note that this is only within the context of SevenFriday's product catalog. Compared to the vast majority of other GMT watches currently on the market, this timepiece remains a rather bold and unconventional choice. For example, SevenFriday's S3/01 "Emerald Carbon" watch features a skeletonized dial and intricately designed hands, creating a more complex visual effect; while the PG/01 GMT opts for a simpler overall design, presenting a retro-futuristic aesthetic, a significant visual breakthrough compared to the classic design of traditional GMT replica swiss watches.
Although the PG/01 GMT's appearance is objectively more understated than many other SevenFriday models, it is still instantly recognizable as a SevenFriday creation. Whether or not you personally like SevenFriday's aesthetic, there's no denying that the company possesses its own unique design language. Furthermore, unlike the bright and vibrant colors of the brand's "Papa Don't Preach" collaboration or the T1/08 "Bauhaus Inspired" watch, the SevenFriday PG/01 GMT primarily uses a monochromatic black/silver color scheme, with only subtle touches of turquoise and yellow on the two hour hands.
Regarding the watch itself, the SevenFriday PG/01 GMT features a case crafted from brushed and polished stainless steel, retaining the brand's signature television-like shape, which is the basic silhouette of most of its timepieces. A slightly domed sapphire crystal glass (with an anti-reflective coating on the inside) covers the dial, surrounded by a bezel with a black lacquered inner ring, visually outlining the dial's contours. Like other SevenFriday watches, the PG/01 GMT features a push-pull crown with the brand logo at 3 o'clock, and the "SevenFriday" logo is engraved at 9 o'clock. It has a standard water resistance of 50 meters (though not outstanding), sufficient for everyday use.
Like other SevenFriday watches, the PG/01 GMT's screw-down case back houses an NFC chip, allowing users to scan the watch using the SevenFriday smartphone app to verify its authenticity and ownership. Each watch is paired with an NFT, and the physical watch is permanently linked to its digital record via an NFC chip embedded in its polycarbonate case back disc. SevenFriday has always maintained a high degree of transparency regarding the origin of its watches; the case back of the PG/01 GMT clearly states that the watch was designed at the brand's Swiss headquarters, the movement is from Japan, and it was assembled in China (the People's Republic of China). While the production methods of countless other watches are similar, SevenFriday's honesty and transparency are still refreshing.
In terms of size, the SevenFriday PG/01 GMT watch has a case diameter of 44.5 mm, a lug spacing of 44 mm, and a total thickness of 13.55 mm. Instead of using lugs that protrude from the side of the case, the PG/01 GMT watch features 26 mm lugs that are directly embedded into the bottom edge of the case. This design makes the watch appear lighter on the wrist than its slightly large diameter suggests. Therefore, the PG/01 GMT replica luxury watches is not particularly thin, and due to the complete absence of lugs, the center of gravity is slightly higher when worn, with the case more like it rests against the upper part of the wrist than wraps around it.
As always, SevenFriday has adopted a rather unconventional and design-focused approach to the dial design of the PG/01 GMT. However, compared to the signature skeletonized dials and gear-shaped hands of most of the brand's other watches, this timepiece is noticeably simpler in appearance. The overall shape of the dial can be described as a small, futuristic mechanical device set against a wide matte black background. Although there is no skeletonization to showcase the movement, the dial still presents a rich visual sense of depth thanks to its multi-layered structure and the three-dimensional shape of its components.
The outermost black area of ​​the SevenFriday PG/01 GMT watch dial has a sloping concave contour, with raised hour and minute markers. Inside this outer area is a brushed silver ring that extends to the 4:30 position, forming the border of the date window. The innermost layer of the dial features a skeletonized rotating disc with a bright yellow hand indicating the second time zone. The hand points to the 24-hour scale printed on a brushed silver ring. This allows the skeletonized hour and minute hands to freely point to the local time zone, with the time displayed on raised markers on the outermost layer of the matte black dial.
The central seconds hand of the SevenFriday PG/01 GMT watch is remarkably small compared to the rest of the dial, its shape somewhat resembling the power symbol commonly found on electronic devices. This tiny running seconds hand is not used for actual timekeeping; its sole purpose is to indicate that the watch is running. However, SevenFriday adheres to a design-first philosophy, and none of its timepieces prioritize extreme functionality. Despite its small size, the 24-hour sub-dial is surprisingly clear, although the local time zone display is less so, as the raised hour markers are located in a recessed area of ​​the dial, easily blending into the matte black dial in low light.
While the hour and minute markers of the SevenFriday PG/01 GMT watch aren't the most legible, its hour and minute hands are particularly striking due to the bold white and turquoise dial. A quick glance is enough to roughly determine the time, but to read the precise minutes, sometimes you need to tilt your wrist until light shines on the raised black markers at the edge of the dial. Similarly, the tips of the skeletonized hour and minute hands are filled with green luminescent material, but since the rest of the watch lacks any luminescent coating, the time can only be roughly determined by viewing the watch in the dark.replica Sevenfriday watches
The SevenFriday PG/01 GMT watch is powered by the Miyota 9075 automatic movement, offering a "pilot's" GMT function, with its 12-hour hand jumping forward or backward in hourly increments. The Miyota 9075 movement is based on the popular Cal. 9xxx platform, oscillates at 28,800 vibrations per hour (4 Hz), and has a 42-hour power reserve. I appreciate SevenFriday's choice of a "pilot's" GMT movement over the more common "call-type" GMT movement. Both GMT complications have their merits and are difficult to categorize; however, the independently adjustable local hour hand is more suitable for travel, giving the PG/01 GMT a more distinct personality and positioning within the brand's collection.
As of this writing, the SevenFriday PG/01 GMT watch is available in two different configurations, with an option of a black leather strap (PG/01) or a stainless steel mesh bracelet (PG/01 M). Both the strap and bracelet are tapered from 26mm at the lugs to 22mm on the inside of the wrist. The leather strap features a stainless steel folding clasp, while the bracelet uses a standard clip-on clasp instead of a sophisticated folding clasp. The PG/01 GMT watch with the leather strap weighs 120 grams, and the bracelet version weighs 168 grams. Because the bracelet size is adjusted by changing the position of the clasp on the mesh structure, the total weight of the watch remains constant regardless of the wearer's wrist size.
Visually, the PG/01 GMT is undoubtedly one of the simplest and most conservative SevenFriday designs in recent years. While its appearance is far from ordinary, it remains instantly recognizable as a SevenFriday timepiece. The PG/01 GMT doesn't represent an aesthetic revolution, but rather an example of the maturing SevenFriday design language over the years. It's not a complex watch with limited functionality, but rather a perfect combination of practical travel complications and an understated appearance (at least by SevenFriday standards), almost obscuring its powerful functionality.
Ultimately, the SevenFriday PG/01 GMT isn't the ideal choice for pragmatists seeking pure practicality; many other GMT watches on the market surpass it in legibility and water resistance. That said, buying a SevenFriday watch isn't solely for practical purposes; the brand's core appeal always stems from its unique and distinctive design.https://www.whereguidewatch.com
yokwoli в оффлайне Old Post 02.03.2026 04:03
Посмотреть профайл автора Click here to Send yokwoli a Private Message Домашняя страница yokwoli Найти еще сообщения от yokwoli Добавить yokwoli в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
