Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > U4N Discusses Arc Raiders Blueprints and Matrix Lore
FlameViper
На форумах с июля 2025
What Are Blueprints and How Do They Actually Work?
In ARC Raiders, blueprints are recipes you must learn before you can craft items, weapons, mods, gadgets, and utilities. They are one of the core progression mechanics in the game, and your ability to build good gear depends on how many you’ve unlocked.
Here’s how it works in practice:
Find the Blueprint During a Raid
Blueprints appear as loot in containers, backpacks, weapon boxes, and other scavenger spots on the surface world. They’re RNG‑driven, so you might go several raids without finding a single one.
Extract Safely to Keep It
If you die before extraction, you lose the blueprint. That’s the same rule as all other valuable loot. Getting out alive is the only way you make progress on your bench collection.
Learn the Blueprint Back at Base
Once you’re home, you open your inventory, select the blueprint, and choose “Learn and Consume.” That permanently unlocks the crafting recipe. You don’t need to learn duplicates.
Craft Items at the Correct Bench
After learning it, you can build that weapon or item as many times as you want as long as:
Your workshop bench is high enough level.
You have the required materials.
This is the real value of blueprints: reliable gear repeatability.
Sell Extras or Use in Progression
If you find duplicates of blueprints you already know, you can either sell them for credits or give them to teammates. There’s no benefit to storing duplicates for crafting.
A frequent community worksheet that many players use is the list of all ARC Raiders blueprints that shows what each one requires and where they might spawn—it’s a handy reference when planning your looting routes, especially if you’re targeting specific weapons or utilities.
Where Should You Look for Blueprints?
Many new players ask “Do blueprints only drop in certain places?” The answer, based on community experience and loot data, is yes and no:
There are specific containers that tend to drop certain blueprint types—like weapon cases or Raider containers.
High‑tier blueprints show up more often during special conditions (like night raids or weather modifiers).
Some maps feel better for farming because they have dense high‑loot areas where blueprint‑rich containers cluster.
Quest and Trial rewards can also give blueprints without relying purely on RNG.
From real play, what helps most is running routes where you can clear as many relevant containers as possible and prioritizing zones that players report good loot density in.
What Does Crafting Progression Look Like?
Once you’ve learned a blueprint and unlocked what you need on your workshop:
You go to the correct bench (gunsmith, utility, explosives, etc.)
Put in the materials
Build the item without relying on random loot spawns
This changes your mindset from “hope I find that gun next raid” to “I can make it if I have the materials.” That matters a lot once you start doing harder content and going for consistent loadout builds.
The better your blueprints, and the more fully upgraded your benches are, the less you’re at the mercy of random gear spawns.
Can You Buy Blueprints?
There’s no official vendor inside the base that just sells all blueprints outright like other RPG crafting games might. Most blueprints must be found or earned through content (loot, quests, trials). However, players sometimes reference item lists—such as listings in sites like ARC Raiders marketplace pages or third‑party stores—but those aren’t the in‑game economy. The true in‑game methods are loot and rewards.
For example, there are third‑party charts that list almost all blueprint recipes, and you might see external sites like ARC Raiders blueprints U4N shop listings that help you track which ones exist—but that’s not an in‑game shop mechanic; it’s a community resource.
What Is “Matrix” Lore in ARC Raiders?
Now for the lore side of the world you’re actually playing in.
The Setting
ARC Raiders takes place in 2180, long after civilization has collapsed due to environmental disaster and a mysterious threat called ARC—a collective of autonomous machines that dominate the surface. Humanity was forced underground into places like Speranza and Toledo.
You play as a Raider: someone who leaves the relative safety of the underground to go topside, scavenge loot, fight ARC machines, and return to improve their home base.
There’s no deep cinematic narrative delivered as a campaign, but the worldbuilding is present in bits of environmental storytelling, NPC dialog, and quest flavor text.
What “Matrix” Means in Player Lore Discussion
The word “Matrix” doesn’t appear in official ARC Raiders lore. But within the community, players sometimes use “Matrix” metaphorically as shorthand when talking about AI dominance or existential themes—comparing the ARC machines’ apparent inscrutable purpose to the idea of a machine‑run world like in The Matrix movie. That’s fan theory and head cannon, not established game lore.
In practice, the game leaves many big story questions ambiguous:
Who built the ARC machines and why?
Are they doing something beyond simply killing humans?
What happened to the rest of the world?
You’ll see hints in lore entries (like the arc falling from the sky after humanity’s collapse, revealing patterns of boom and bust in civilization), but official narrative details are sparse.
What Lore Actually Shapes Your Experience?
In the actual gameplay world:
Humanity is struggling. Your underground settlement depends on Raiders to bring back materials.
ARC machines are the enemy everywhere outside base walls. You don’t know exactly why they are here, only that they threaten survival.
There are factions and NPCs who have identities and goals (traders, quest givers, etc.) but they don’t yet have a sweeping, cinematic storyline attached to them.
In other words, most of the story you feel as a player comes from your actions and outcomes, not from a cutscene telling you the plot.
Practical Tips for Players
Here are concrete things that help in normal play:
Prioritize extraction when you find a blueprint—losing it to death wipes your progress for that item.
Track what you already know so you aren’t looting duplicates you don’t need.
Upgrade your benches as soon as you can; it’s the only way to make the useful gear.
Community route planning (routes for container clearing) pays off much more than random roaming.
If a blueprint is eluding you, consider quests and trials that reward specific ones—those are more deterministic than pure RNG.
FlameViper в оффлайне Old Post 24.03.2026 03:05
Время на форуме соответствует Гринвичу . Сейчас время - 11:53. Новая тема   Ответить
