Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Flame > U4GM Guide Best Voyak KT 3 Loadout for BO7 Season 2 Reloaded
Hartmann846
На форумах с марта 2026
Ever since Season 2 Reloaded landed, the Voyak KT-3 has been everywhere. You load into a match and, yep, there it is again. After a bunch of testing, I get why people won't put it down: that built-in range finder is genuinely useful, especially when you're trying to hold lanes or pick off runners across rooftops. If you're warming up, tweaking your aim, or just trying to get clean reps without the chaos, hopping into a CoD BO7 Bot Lobby can make it easier to feel the rifle's pacing. The downside is obvious once you start stretching it out—rate of fire feels a touch slow, and the recoil can bounce when you panic-spray.
Optic and Muzzle
First change I'd make: get rid of the irons. They're chunky, they eat your screen, and they make tracking a pain once the fight gets messy. The Fang Hover Point Elo cleans the sight picture up straight away, and it helps you read your recoil instead of guessing. After that, the Redwell Shade-X Suppressor is doing a lot of heavy lifting. It calms both the vertical rise and that annoying side-to-side wobble, and staying off the minimap is still a big deal when the lobby's full of players pre-aiming corners.
Barrel, Grip, and Stock
Next up, fix what the Voyak struggles with at range. The 19.2" Greaves-CS Barrel is the one—bullet velocity feels way more consistent, and you'll notice fewer shots "missing" when you swear your crosshair was on them past 40 metres. Then I like the Crisis-Q Grip because it keeps the gun feeling quick. The Voyak hits hard, but it's not worth much if you're always a beat late on ADS. To round it out, the Bowen Tread Pad stock gives you that aim-walk strafe speed so you can stay on target while moving, instead of planting your feet and hoping you don't get deleted.
Class Pairing and Play Tips
You'll still want a backup plan for tight spaces. The Voyak can lose ugly point-blank trades just because it doesn't spit bullets fast enough. Pair it with a Sturmwolf 45 SMG built for speed—short barrel, suppressor, and anything that keeps sprint-to-fire snappy. For equipment, Stimulant is the difference between re-challing and getting chased down while weak, and Semtex is great for clearing head glitches and those "I'm not moving" players. Perk-wise, Ninja keeps you quiet, and Pillage helps you avoid that awful moment where you're mid-reload and someone slides you.
Keeping It Competitive
If you build the Voyak like this, it stops feeling like a temperamental bruiser and starts behaving like a steady workhorse you can actually trust at mid-to-long range. Spend a few games focusing on burst control, then widen your spray once you've got the rhythm—this gun rewards calm hands more than flashy ones. And if you're looking to speed up your overall grind with quick, reliable services for game currency and items, it's worth checking out U4gm early so your loadouts come online faster without wasting whole nights farming.
Hartmann846 в оффлайне Old Post 28.03.2026 04:51
Посмотреть профайл автора Click here to Send Hartmann846 a Private Message Найти еще сообщения от Hartmann846 Добавить Hartmann846 в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 21:02. Новая тема   Ответить
