Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Flame > U4GM Where to Use the Dam Testing Annex Key in ARC Raiders
Hartmann846
На форумах с марта 2026
The Dam Testing Annex Key is one of those drops you don't plan around—you just notice it sitting in your bag and your brain immediately starts doing routes. I've only ever seen it show up from random containers, and every now and then from a job payout, so treating it like it's replaceable is a quick way to regret a run. If you're still sorting out what's worth keeping and what's junk, it helps to get familiar with ARC Raiders Items so you don't ditch something that's actually a big deal mid-session.
Finding the right building
When you're ready to spend the key, queue into Dam Battlegrounds and head for the southeast side of the map. You're looking for the Testing Annex—big, boxy, research-looking, and usually busy. People waste time checking ground-level doors because it feels like the lock should be up there. It isn't. Get inside the main structure, move through the hallways and common rooms, and keep an eye out for a central stairwell that actually goes down, not up. That's your real start point.
Basement trick that burns first-timers
Go down into the basement and slow it down for a second. This is where a lot of players mess up. There are two separate locked doors down there, close enough that you'll think it's one loot room with multiple entrances. Both doors take the same key. And yes, the key gets consumed on use. So if your plan is to clear everything behind both locks in one raid, you need to bring two keys, not one. Otherwise, pick a door, commit, and don't stand around second-guessing while someone else hears you.
Loot, noise, and getting out alive
Behind either door, the payoff is real: stacked high-tier containers, better crafting materials than you'll pull from most surface routes, and the kind of weapon and mission-item spawns that make the trip feel worth it. But it's also loud gameplay. You're opening doors, shuffling loot, and staying in one spot too long. Before you unlock anything, sweep the upper floors first, then pause and listen. Footsteps above you travel. So do reloads. Plan your exit before you touch the lock, and don't be afraid to bail early with a half-full bag if you've already hit the good boxes. If you're trying to fund more geared runs, pairing smart key usage with steady income like cheap ARC Raiders Items can make those losses hurt a lot less when the basement turns into a firefight.
Hartmann846 в оффлайне Old Post 28.03.2026 04:52
Посмотреть профайл автора Click here to Send Hartmann846 a Private Message Найти еще сообщения от Hartmann846 Добавить Hartmann846 в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 19:55. Новая тема   Ответить
