Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > WBC Mini Season Farming Guide in MLB The Show 26 for Maximum Rewards
If you want to make the most of your World Baseball Classic (WBC) Mini Season in MLB The Show 26, it’s all about efficiency. This repeatable mode is the fastest way to earn high-tier packs, stubs, and XP—especially when you stack missions and optimize your playthrough. Here’s a simple, step-by-step guide to farming the Mini Season for maximum rewards.
Set Up for Speed
1. Pick the Right Season Settings
Season Length: Go for the 7-game Mini Season option. It lets you hit the playoffs quickly without grinding through a full 28-game schedule.
Inning Length: 3-inning games keep the pace fast. Less time, same rewards.
Difficulty: Rookie is best for consistent hitting and clearing stat-based missions.
2. Use a Favorable Stadium
Choose a stadium with short outfield dimensions when you are at home. Names like "Costco" or "Blank Canvas" make home runs easier, which speeds up both gameplay and mission completion.
The “Win 3, Quit 4” Loop
This method is a favorite for high-efficiency farming:
Win the First 3 Games
Clears early missions and builds momentum for playoffs.
Quit Game 4
Save time by forfeiting. You still remain in a playoff position.
Win the Championship
Play the postseason for the highest reward concentration. Packs, stubs, and XP stack here.
Mission Stacking Tips
Fill Your Lineup with WBC Cards: Progress Team Affinity missions and WBC player challenges while completing Mini Seasons.
Focus on Stat Missions: Missions like “Tally 56 runs” or “Record 20 strikeouts” are repeatable and efficient.
Leverage XP & Rewards: Each full cycle can earn up to ~37,000 stubs and 25,000 XP, alongside packs like the 10-pack Standard bundles and “Ballin’ is a Habit” packs.
Key Rewards to Target
Players: 88 OVR stars such as Alex Bregman, Brandon Nimmo, Luis Robert Jr., and Ryan Helsley.
Packs: Standard 10-packs, Deluxe WBC packs, and specialty Ballin’ packs.
Exchange Items: Championship banners can be traded for 5-pack Ballin’ bundles.
Pre-Farm Checklist
Before diving into Mini Season farming, make sure your squad is ready:
Complete WBC Moments: Earn 30 program points per pool to unlock early rewards.
Run WBC Showdowns: Add diamond-tier players to strengthen your lineup.
Enter Mini Season Loop: Prioritize repeatable stat missions to maximize packs and stubs.
By following this strategy, you can efficiently farm the WBC Mini Season without wasting time. For players looking to skip the boring grind, U4N is a trusted platform used by competitive players to focus on practicing while still hitting big rewards. And if you need additional cards or resources quickly, check out the MLB The Show 26 Shop for stubs and pack bundles to keep your squad competitive.
Focusing on speed, stacking missions, and using the right tools makes Mini Season farming in MLB The Show 26 both fast and rewarding. Stick to this guide, and you’ll be stacking diamond players and packs in no time.
AmandaMartin в оффлайне Old Post 18.04.2026 02:35
