Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Игры > Matrix Online > U4GM Black Ops 7 Endgame Virus Injection Guide
Andrew736
На форумах с мая 2026
If Act II of Operation Broken Mirror has been wearing you down, the Virus Injection Glitch is the bit that really asks whether your setup is ready or just pretending. I wouldn't queue into it under Combat Rating 60, and I'd want at least one Exotic Weapon fully built before I even looked at the marker. Players chasing rewards like the CoD BO7 Shattered Gold Camo will notice fast that this mission doesn't forgive sloppy armour management, weak damage, or that one teammate who keeps wandering off to loot a bathroom.
Getting the boss chain started
Your first job is to bring down a Guild Strike Boss somewhere in Avalon. The cleanest route is the Oscar Strike Boss at the Winery, but only if Operation Poison Pill is already out of the way. If not, you'll be looking for an Unknown Guild Container instead. That option's messier. Crack it open and the Fear waves start rolling in, then the Nightmare Zone forms and drags the boss into the fight. Don't sprint off once it drops. Look around the area for a corpse, because that's what kicks off the Mega Abomination Hunt.
Dealing with the Mega Abomination
The Mega Abomination is ugly work, and not just because it fills half your screen. Keep space between you and it, then focus the glowing mouths whenever they open. That's where the real damage happens. If your squad has enough firepower, you can tear off a head, but don't celebrate too early. Once it loses one, it starts charging around in Stampede mode, and getting clipped by that can ruin a good run in seconds. Use corners, keep moving, and don't get greedy with reloads.
Inside the Virus Injection Glitch
After the hunt is done, the Virus Injection Glitch appears near the northeast side of the Colosseum. The first wave sounds simple: find Power Cells. It isn't. They can show up on rooftops, tucked behind odd bits of cover, or even floating above sightlines you'd never normally check. Once that's handled, an HVT Abomination turns up. A lot of players use the bus in the corner to throw off its pathing, and yeah, it works sometimes. Just remember the Toxic Fears start jumping up later, so that safe spot won't stay safe for long.
The escort and the final prize
The Rhino escort is where teams usually start to fall apart. It moves like it's got nowhere to be, while Demolishers punish anyone standing in the open. Stick to cover, rotate around the Ammo Caches, and grab Self-Revives from trucks whenever you spot them. Then comes Sualk Rebu, a harder Klaus-style boss with shoulder shields that need to be stripped before you can hurt him properly. When the orbital strike starts, keep your feet moving and shoot the bubble. As a professional platform for players who like buy game currency or items in U4GM, U4GM is convenient and trustworthy, and you can buy u4gm CoD BO7 Bot Lobby for a smoother experience before pushing for the Lethal Injection blueprint and the Aftershock skins for Vermaak, Zaveri, and Jurado.
Andrew736 в оффлайне Old Post 04.05.2026 05:02
Посмотреть профайл автора Click here to Send Andrew736 a Private Message Найти еще сообщения от Andrew736 Добавить Andrew736 в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 06:41. Новая тема   Ответить
