Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > Efficient Skill Points Farming Methods in Forza Horizon 6
Farming Skill Points (SP) efficiently in Forza Horizon 6 comes down to understanding one simple rule: a single skill chain caps at 500,000 total score, granting a maximum of 10 Skill Points. To get the most out of your time, you need to bank points before exceeding your car’s multiplier threshold—examples include 71,500 × 7 or 100,000 × 5. Once you hit this threshold, stop the chain, bank the points, and immediately start a new one.
Best Vehicles for Farming
Your choice of vehicle can drastically speed up your SP farm. Look for cars with high built-in multipliers or special skill perks:
Subaru BRZ Forza Edition – Found in the mountain area. Its Car Mastery tree gives large combo bonuses, wreckage skill boosts, and extended chain duration.
Lotus Evija Forza Edition – A strong drift machine with an integrated drift multiplier, great for early-game SP farming.
Mazda MX-5 – Affordable and flexible; the perk tree allows you to increase your multiplier up to 7x.
Top 3 Open-World Farming Locations
Pair your car with Skill Songs on the radio for up to a 10x multiplier. These locations are community-tested for max SP gain:
Snowy Mountain Slopes
Head to the mountain tops and drift through dense snow-covered forests. Smashing small trees combines Drift, Wreckage, and Air Time (Kangaroo) skills for a massive score.
Tokyo City Fields
Use the large open plains outside the city. Lock your car in 2nd gear using manual transmission to control slides and build huge Drift and Side Swipe combos.
Festival Mountain “Donut” Loop
Drive continuous donuts and drifts around the mountain festival loop. The layout minimizes crashes into indestructible objects while stacking SP efficiently.
1-Minute EventLab Blueprint Method
If you want to bypass open-world driving, community creators have built automation tracks in EventLab:
Go to the Creative Hub → EventLab → Blueprint Events.
Search for tags like Karmadriving or events titled “Ultimate Best Skills 10 SP in 18s” / “Easy 100k in 30 seconds”.
Set your Game Settings to Auto-Steering.
Hold the accelerator; the car will smash through perfectly placed objects, banking 9–10 SP in under a minute.
After the race, choose Restart Race to instantly repeat and stack points.
Passive “Semi-AFK” Circuit Farming
For long, passive sessions:
In EventLab, search for custom “CR Money” or long highway circuits.
Enable Auto-Steering.
Secure your controller’s accelerator with a rubber band or hair tie.
Let your car continuously run the path to farm SP, XP, and Credits for hours without active input.
By combining the right car, multiplier perks, and optimized locations, you can farm Skill Points faster than ever in Forza Horizon 6—whether actively drifting through snowy slopes or passively running custom EventLab circuits.
AmandaMartin в оффлайне Old Post 17.05.2026 22:44
Время на форуме соответствует Гринвичу . Сейчас время - 19:01. Новая тема   Ответить
