U4N: Forza Horizon 6 Guide to Car Meets and Convoys
Forza Horizon 6’s transition to the neon-soaked streets and winding mountain passes of Japan has brought a massive wave of visual and social upgrades. The core game engine now supports up to 12 players in a single private Convoy and up to 72 players in a single “Horizon Life” freeroam session. If you want to drop the solo grind, escape the AI drivatars, and actually roll with a crew, you need to understand how the new Car Meets and Convoy mechanics function.
This guide breaks down exactly how to assemble your squad, where to find the best spots to show off your builds, and how to maximize your in-game time.
Setting Up Your Convoy Without the Headache
The system backend relies entirely on the Xbox platform infrastructure, meaning you have total crossplay parity whether you are on PC, Xbox Series X/S, or PlayStation 5. The old, laggy peer-to-peer transitions are gone; server sharding handles player phasing instantly.
How to Build Your Party
To get your friends into the same instance, open your pause menu and jump over to the Online tab, then select the Convoy tile.
Quick Controls: Press Y (Xbox/PC) or Triangle (PS5) to open the management menu instantly.
Privacy Controls: You can set the lobby to Friends Only or toggle it to Open with a specific behavioral tag like Cruising, Drag Meets, or Touge Showdown so random players looking for the same vibe can find you.
Accepting Invites: When a friend accepts an invite, the engine phases them directly into your coordinates in under 8 seconds without putting anyone through a loading screen.
Operational Limit Note: Only the designated Convoy Leader can place group waypoint routes on the map and launch official Horizon Play events. If you join someone else's Convoy, your personal career progress pauses, but you still earn full credits and XP.
Finding the Hotspots: Open-World Car Meets
You don't need to stay glued to a menu to show off your custom liveries. Forza Horizon 6 introduces dedicated, physical parking areas and social hubs scattered around the map where you can drive right in, park, and interact.
The Iconic Meet Locations
The map features three massive, permanent meetup locations necessary for the “Parking All Over The World” achievement:
Daikoku Parking Area (PA): The undisputed crown jewel of the car meet feature. Modeled directly after the real-world legendary highway rest stop, it serves as the primary hub for JDM builds, midnight highway runners, and clean stance projects.
Shibuya Underground Garage: A multi-level subterranean concrete paradise perfect for showing off custom underglow and neon paint jobs away from the rain.
The Northern Rest Stop: A scenic, rural lot nestled right at the base of the mountain touge passes, usually populated by drift missile builds and classic sports cars.
When you pull into a marked space at these locations, hitting the on-screen prompt lets you switch to an on-foot character view. From here, you can inspect adjacent builds, instantly download another player’s custom tuning setup, copy their paint design, or buy a factory stock version of their vehicle directly from the local dealership menu.
Maximizing the Economy: Upgrading Your Garage
Building high-tier drift builds or maxing out an absolute weapon for highway pulls gets expensive quickly. A single competitive S1 or S2 class optimization pass can easily wipe out hundreds of thousands of credits.
While running multiplayer events is highly lucrative, the quickest path to securing rare aftermarket imports is to keep your budget healthy. For creators and players looking to skip the repetitive credit grind and focus purely on aesthetics and community builds, you can safely look to external platforms. A highly reliable shortcut to stock your virtual garage with top-tier machinery is to buy forza horizon 6 credits online through verified gaming networks like U4N, allowing you to bypass weeks of repetitive race farming and get straight to customizing your dream build for the next meet.
Integrated Activities: From Parking to Racing
Once your convoy is assembled at a car meet, you aren't just limited to staring at parked metal. The developers added seamless, zero-load transition activities directly into the open world.
1/4-Mile Drag Strips
Certain highway stretches directly outside the Daikoku PA feature active "Drag Meet" staging lanes. If you and your Convoy members pull into the parallel lanes, the game environment automatically triggers a Christmas tree light sequence and lines you up for a clean, 1/4-mile sprint with automated timing boards at the finish line.
Touge Battles (1v1 and 2v2)
If your crew prefers cornering over straight lines, head up to the mountain passes. The Horizon Play suite allows the Convoy Leader to instantly launch a Touge Showdown directly from free roam. This locks the participants into a tight mountain serpentine layout where the lead car wins by gapping the chaser, and the chase car wins by overtaking.
The Co-op LINK Skills System
Cruising tightly down the highway or hitting a drift zone together rewards you in real-time. When Convoy members execute actions simultaneously—like tandem drifting within a few feet of each other or catching air off a ridge at the exact same moment—the UI triggers a yellow-green Link Skill multiplier. This combines the skill scores of everyone involved, letting you clear Horizon Playlist skill challenges significantly faster than you ever could solo.
Convoy Troubleshooting Checklist
If you're getting dropped invitations or can't see your friends in the parking lot, run through these numbers quickly:
Verify Crossplay: Go to Pause Menu > Campaign > Settings > HUD & Gameplay and ensure Online Crossplay is toggled to Enabled.
Check the Progression Lock: New players cannot join a Convoy or access Car Meets immediately. You must first clear the introductory prologue and the initial street race through Tokyo alongside Mei. Once you cross that finish line in the borrowed Nissan Silvia, the entire online sandbox unlocks.
Ghosting Issues: If a Convoy member is invisible but appears in your party list, have the Leader quickly set a map waypoint. The forced server update usually forces the sharding system to snap the missing vehicle back into your physical instance.
