Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > U4N: How to Build a Fast AWD Car in Forza Horizon 6
The vast virtual map of Japan in Forza Horizon 6 is a playground of contrasts, stretching from the tight, glowing, neon-lit corridors of downtown Tokyo to the sweeping, rain-slicked mountain passes of Mount Fuji. In this world, Rear-Wheel Drive (RWD) builds can be incredibly rewarding, but when you want raw, unadulterated speed through a rainstorm, instant launch off the grid, and the ability to correct a bad angle at 150 mph, All-Wheel Drive (AWD) remains king.
Building a dominant AWD monster isn't just about slapping an AWD drivetrain swap onto a high-horsepower supercar and maxing out the Performance Index (PI) bars. FH6 introduced key updates to tire physics, track widths, and brake lock-ups that heavily penalize lazy tuning. If you want to build a truly fast AWD car that turns on a dime and crushes lap times, you need a precise, calculated approach.
Step 1: Choosing Your Platform (The PI Strategy)
A common mistake is taking an S2-class hypercar, throwing more power at it, and hoping for the best. To build something genuinely lethal, look for a platform in the lower classes that has room to breathe.
For example, a 2021 Volkswagen Golf R starts in B-Class, while JDM favorites like the 2024 Nissan GT-R NISMO or 2022 Acura NSX Type S start as mid-to-high S1 platforms.
When configuring your baseline, remember the PI golden rule: prioritize weight reduction over pure horsepower. In FH6, chassis rigidity and low mass heavily dictate how much speed you carry through technical chicanes.
Weight Reduction: Go for the Race Weight Reduction immediately. Dropping 300–500 lbs from a vehicle does more for your 0–60 time and cornering g-forces than adding 150 horsepower, and it often costs fewer PI points.
Brakes and Suspension: FH6 drastically changed brake mechanics. Stock brakes now suffer from severe lock-ups during rapid downshifts. Budget enough PI points for at least Sport or Race Brakes, alongside a Race Suspension and Anti-Roll Bars (ARBs) to unlock fine-tuning capabilities.
Step 2: The Horizon Market & Upgrades
As you start accumulating credits and working your way through the Horizon Festival ranks, you will notice that maximizing a car's potential requires specific high-tier components. While traditional progression involves winning events and completing your Collection Journal, smart players frequently look for shortcuts to secure specialized performance parts.
Many players turn to external marketplaces like U4N to safely pick up rare forza horizon 6 items, custom-tuned Forza Edition cars, or additional wheelspins to fast-track their builds without endless grinding. Having access to these resources early on allows you to skip the baseline part-farming phase and dive straight into advanced engine swaps and tire compounds.
When selecting parts in the upgrade garage:
Tire Width is Overpowered: Unlike previous titles, widening your front tires is highly cost-effective in FH6. Increasing front width maximizes turn-in grip, which helps mitigate the natural understeer characteristic of AWD drivetrains.
Transmission: Pick a Sport or Race Transmission. Sport unlocks the crucial final drive ratio tuning, while Race allows for seamless sequential shifting, entirely bypassing the need to waste PI on clutch upgrades.
Differential: Always install a Race or Rally Differential. AWD means nothing if you can't control how power splits between your front and rear wheels.
Step 3: The "Anti-Understeer" AWD Tuning Blueprint
Once your parts are installed, it is time to tune. A standard, untuned AWD car suffers from "plowing"—it wants to go straight when you mash the throttle mid-corner. To fix this, you must distribute power, stiffness, and alignment mathematically to make the car rotate like an agile RWD platform while maintaining AWD traction.
Open the tuning menu and apply these foundational guidelines, tailored for a high-performance S1-Class (900 PI) or S2-Class (998 PI) road racer:
1. Tires & Alignment
Tire Pressure: Set to 28.0 PSI front and rear. As tires heat up during a race, pressure rises. Target an optimal hot pressure of roughly 32.0 PSI for peak contact patch stability.
Camber: Set Front Camber to -2.0° and Rear Camber to -1.5°. This gives the car negative tilt, ensuring that when the body rolls into a hard turn, the outer tires flatten completely against the asphalt.
Toe: Set Front Toe to 0.1° (Out). Do not touch the rear toe. That slight front outward angle dramatically sharpens your initial steering turn-in response.
2. Anti-Roll Bars (ARBs) & Springs
AWD cars need a soft front end and a stiff rear end to balance out chassis rotation.
Anti-Roll Bars: Set Front ARBs to 15.00 (relatively soft) and Rear ARBs to 45.00 (stiff). This intentional imbalance forces the rear end to swing around slightly under hard cornering, fighting off understeer.
Springs: Match the ARB logic. Keep front spring stiffness moderately lower than the rear. Lower the ride height until the car sits low to the ground for a lower center of gravity, but leave about 0.5 to 1.0 inch of clearance from the absolute minimum to prevent bottoming out on Tokyo's bumps or curbs.
3. Differential (The Magic Formula)
The differential settings are where an AWD car truly becomes fast. You need to tell the center differential to behave more like a rear-wheel drive car under acceleration.
Differential Parameter Front Setting Rear Setting
Acceleration 40% 85%
Deceleration 0% 15%
Center Balance (Power Bias): Slide this to 70% - 75% Rear. This sends nearly three-quarters of the engine’s torque directly to the rear wheels when you stomp on the gas. It allows you to break the rear loose just enough to point the nose of the car toward the apex, while the 25% front power pulls you out of the corner cleanly like a rocket.
Building a top-tier AWD car in Forza Horizon 6 comes down to countering the system's inherent flaws. By keeping your build light, widening your front track width to grab the tarmac, softening your front anti-roll bars, and sending at least 70% of your power to the rear differential, you eliminate understeer entirely.
Take your newly tuned machine to the technical mountain passes or the wide-open expressways. You will immediately notice the difference: instant launch off the line, absolute control in the rain, and corners executed with surgical precision.
AmandaMartin в оффлайне Old Post 30.05.2026 00:45
Время на форуме соответствует Гринвичу . Сейчас время - 16:12. Новая тема   Ответить
