U4N: How to Tune for Rain Racing in Forza Horizon 6
We’ve all been there: you’re leading an online lobby in Forza Horizon 6, the sky turns dark, the downpour starts, and suddenly your 900-horsepower hypercar feels like it’s driving on wet soap.
Forza Horizon 6’s weather system introduces dynamic track temperatures and puddles that cause hydroplaning. If you take a dry-track tune into a heavy storm, you will spin out on corner exits and slide straight through breaking zones. You don’t need a completely new car for wet weather, but you do need to alter how your chassis transfers weight.
Here is how to modify your setup to dominate in the rain, using concrete telemetry numbers.
1. Tires: Lower the Cold Pressure
In dry conditions, you want your tires to heat up and expand to an optimal hot pressure of around 33 PSI. In the rain, however, the wet asphalt constantly cools the rubber, meaning your tires might never reach that target.
If your dry setup starts at 28.5 PSI, drop your cold tire pressure to 26.0 PSI or 26.5 PSI for rain racing. Lowering the pressure does two things:
It widens the physical footprint (contact patch) of the tire on the road.
It allows the tire carcass to flex more, creating internal friction that helps generate vital tire temperature despite the cold rainwater.
2. Suspension: Soften the Springs and Anti-Roll Bars (ARBs)
A stiff car is a fast car on dry, smooth tarmac, but stiffness is your enemy in the wet. When the track is slippery, you need weight transfer to push the tires into the ground to create mechanical grip.
Let's look at a concrete example using an A-Class AWD build with a 55% front weight distribution:
Dry Setup: Front ARBs at 22.0, Rear ARBs at 28.0. Springs set to 700 lbs/in (Front) and 600 lbs/in (Rear).
Rain Setup: Drop your ARBs significantly. Try 12.0 Front and 16.0 Rear. For the springs, reduce the stiffness by roughly 15% to 20%—bring the front down to 580 lbs/in and the rear to 490 lbs/in.
Softer anti-roll bars and springs slow down the chassis movements. When you turn the wheel or hit the gas, the car rolls gently instead of snapping, giving you a much wider, more forgiving window to catch a slide before it ends in a barrier.
3. Alignment: Less Camber, Touch of Toe-In
Because a rain-optimized car rolls more, you might think you need more aggressive camber. The opposite is true. Because overall cornering speeds and lateral G-forces are lower in the wet, the tire doesn't roll over onto its shoulder as violently as it does on dry asphalt.
If you run -2.0° of front camber and -1.5° of rear camber in the dry, dial it back to -1.5° front and -1.0° rear. This keeps the tire flatter on the ground during braking and acceleration, which is exactly where you lose the most time in the wet. Additionally, adding 0.1° of Rear Toe-In stabilizes the back end of the car when splashing through deep puddles at high speeds.
Adjusting your build requires in-game currency for parts, and if you want to skip the grind of completing endless playlist events just to fund your garage experiments, you can check out platforms like u4n to pick up some cheap FH6 credits. Having a bankroll lets you build multiple rain-specific duplicates of your favorite cars without worrying about the cost of wet-weather test setups.
4. Damping: Soften the Bump and Rebound
Damping controls how fast the suspension compresses (Bump) and extends (Rebound). In heavy rain, standing water creates sudden resistance against the tires. If your bump damping is too stiff, hitting a puddle at 120 mph will upset the chassis and cause instant hydroplaning.
Drop both your Front and Rear Bump Stiffness down to a low range of 3.0 to 4.5. Keep your Rebound Stiffness relatively soft as well (around 8.0 to 9.5). This setup allows the dampers to absorb the impact of standing water without throwing the car off line.
5. Differential: Open It Up
A locked differential forces both wheels on an axle to spin at the same speed. On a wet surface, if one wheel hits a puddle and loses grip, a highly locked differential will instantly break traction on the opposite wheel, causing a sudden spin.
Open up your differential sliders to allow more slip:
RWD Acceleration: Drop from a dry baseline of 75% down to 45% - 50%.
AWD Deceleration: Keep this low, around 10% - 15%, to prevent the car from sliding sideways when you lift off the throttle entering a wet corner.
Wet Weather Tuning Cheat Sheet
Setting Category Dry Baseline Rain Adjustment Why it Works
Tire Pressure 28.5 PSI 26.0 - 26.5 PSI Increases contact patch; builds tire heat.
Anti-Roll Bars 22.0 / 28.0 12.0 / 16.0 Slows down body roll; makes slides predictable.
Springs 700 / 600 lbs 580 / 490 lbs Promotes mechanical weight transfer for grip.
Camber -2.0° / -1.5° -1.5° / -1.0° Maximizes flat tire contact for wet braking.
Diff Accel (RWD) 75% 45% Prevents inside wheelspin from spinning the car.
