Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > U4N: Best AWD Builds in Forza Horizon 6
With Forza Horizon 6 taking the festival to the highly technical, corner-heavy roads of Japan, maximizing corner exit speed and launch traction is more critical than ever. Whether you are attacking the narrow hairpins of the Touge mountain passes or blasting through the neon-lit grid of downtown Tokyo, All-Wheel Drive (AWD) remains the dominant meta for online racing.
While AWD ensures incredible launches and massive grip, the game features a slight inherent understeer bias when you push too hard into a corner. To build a true podium-contender, you have to counter this by tuning mechanical balance and power distribution. Here is the breakdown of the absolute best AWD setups, specific tune metrics, and why they work.
The S1-Class Dominator: 1990 Nissan #12 Skyline GT-R (BNR32 Gr.A)
Forza Horizon 6 features the massive, intricate urban landscape of Tokyo alongside iconic Japanese mountain passes. In the competitive S1 class (up to PI 900), the legendary Group A "Godzilla" Skyline is an absolute beast when converted to a clean, optimized road racing spec.
Because S1 racing rewards lightning-fast acceleration out of low-speed corners, the goal here is to give the chassis a rear-biased setup to combat understeer while retaining maximum AWD launch grip.
The Component Build
Engine & Power: Keep the stock racing engine but maximize the intake and exhaust to hit around 680 horsepower. Avoid heavy camshaft upgrades if they push you over the PI ceiling without providing equivalent handling value.
Platform & Weight: Apply Race Weight Reduction to bring the vehicle mass down near 1,180 kg. Add Race Front and Rear Anti-roll Bars (ARBs) to unlock full chassis adjustment.
Tires & Drivetrain: Equip Race Tire Compound and widen the rear tires to a massive 375 mm patch. Install the 6-speed Race Transmission and the Race Differential.
The Precision Tune Metrics
To make this heavy-hitting AWD platform rotate beautifully like a rear-wheel-drive car on entry while rocketing away on exit, apply these exact settings:
Tuning Parameter Front Axle Setup Rear Axle Setup
Tire Pressure 1.1 BAR (16.0 PSI) 1.1 BAR (16.0 PSI)
Camber Alignment -2.0° -1.5°
Toe Alignment 0.2° (Out) 0.0°
Anti-roll Bars (ARBs) 18.00 (Soft) 38.00 (Stiff)
Spring Stiffness 45.0 kgf/mm 75.0 kgf/mm
Differential Acceleration 100% 85%
Differential Deceleration 0% 35%
Center Differential Balance: Set the center distribution slider to 75% to 80% Rear Bias. This sends the vast majority of the torque to the rear wheels when putting the power down, keeping the front wheels from pulling the car wide into the guardrails on a tight apex.
The A-Class All-Rounder: 2004 Subaru Impreza WRX STI
If you are looking for a build that handles both the street circuits and the treacherous dirt paths of the Horizon Kaido trails, the B600 to A700 progression on the 2004 Subaru WRX STI is incredibly reliable.
AWD swaps on natively RWD cars take a significant Performance Index (PI) penalty. The massive advantage of starting with native forza horizon 6 cars like the WRX STI or the Mitsubishi Lancer Evolution is that they feature perfectly optimized factory center differentials. This means you do not waste precious PI points on drivetrain conversions, allowing you to dump that extra budget directly into pure power-to-weight ratio and mechanical grip. When purchasing upgrades through U4N, focusing on these native platforms stretches your in-game credits much further.
The Component Build
Tires: For an all-around street/dirt blend, use the Rally Tire Compound. It lowers the PI index compared to full slick race tires, letting you put more horsepower under the hood.
Chassis: Opt for Rally Springs and Dampers. This gives the car enough travel to absorb the bumps of rough Japanese backroads without losing traction, while remaining composed on flat tarmac.
Alignment: Set the front caster to 5.5° to stabilize the steering wheel during high-speed transitions. Keep the front tire pressures low at 1.1 BAR to maximize the contact patch.
Damping: Set your Rebound Stiffness to 8.5 front and 11.5 rear. For Bump Stiffness, go soft with 3.5 front and 2.5 rear. This allows the suspension to compress quickly over uneven asphalt or dirt crests, preventing the car from bouncing and losing power delivery.
AWD Differential Split: Run 35% Front Accel / 0% Front Decel, and 90% Rear Accel / 25% Rear Decel. Push the Center Balance slider to 70% Rear. This gives the car a highly responsive rally-style rotation; tapping the e-brake causes the rear to step out smoothly, allowing you to slide through hairpins while the front wheels quickly pull you straight once you hammer the throttle.
Core Rules for Building Your Own AWD Meta Tunes
If you want to apply these philosophies to other platforms in your garage, remember these three foundational physics rules of the current tuning sandbox:
Keep the Front Soft, Rear Stiff: Setting your front Anti-roll Bars significantly softer than the rear (e.g., 15 front / 40 rear) forces the car to lean on its outer rear tire during a turn, drastically reducing the natural understeer plaguing most AWD vehicles.
Drop the Tire Pressure: Unless you are drag racing, keeping your tire pressures locked at or near 1.1 BAR (16.0 PSI) on both axles yields the highest mechanical lateral G-force across almost every tire compound.
Don't Over-Lock the Front Diff: Keeping front deceleration at 0% ensures the car turns in freely when you lift off the throttle, while keeping front acceleration under 40% prevents the front tires from spinning wildly and washing out wide during corner exits.
AmandaMartin в оффлайне Old Post 03.06.2026 23:28
Время на форуме соответствует Гринвичу . Сейчас время - 07:40. Новая тема   Ответить
