Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > U4N: arc raiders burletta blueprint location
FlameViper
На форумах с июля 2025
In ARC Raiders, tracking down high-tier blueprints is the ultimate end-game loop. While standard weapons can be looted from random crates across the surface, some of the best gear is hard-locked behind trader progression. A prime example is the Burletta I—a highly effective, fast-firing semi-automatic sidearm that shreds shields and dominates close-quarters PvP encounters.
If you are trying to find the Burletta Blueprint by kicking down random doors, stop wasting your time. It cannot be found in random topside loot containers. Instead, it is a quest-exclusive reward earned by completing the "Industrial Espionage" quest given by the weapons trader, Tian Wen.
How to Unlock and Complete the Quest
Unlocking the quest requires consistency, and completing it requires caution. The entire loop can be broken down into a five-step tactical checklist.
1. Build Trader Reputation
You won't get this mission right out of the gate. You must progress through lower-level missions to build enough reputation with Tian Wen in Speranza to unlock her advanced "TN1" questline. Specifically, you need to clear the "Eyes On The Prize" mission first. Once that prerequisite is met, Tian Wen will officially offer you "Industrial Espionage."
2. Guard the Quest Item
Upon accepting the assignment, Tian Wen will hand you a standard, stock Burletta pistol. Do not modify it. Adding attachments like extended mags or sights will alter the item's data signature, causing the quest prompt to fail when you reach the drop point.
More importantly, do not lose it. Because ARC Raiders features a high-stakes, full-lose extraction economy, dying on your way to the objective means losing the gun. If a hostile squad wipes you, you'll have to buy a replacement directly from Tian Wen’s shop for 8,700 ARC Raiders Coins.
Pro-Tip: If you are struggling to survive the trek or want a permanent shortcut to skip the grind entirely, third-party marketplaces like U4N offer options to buy arc raiders blueprints xbox variants or raw materials to buffer your stash before risking high-value runs.
3. Navigate to the Buried City Cache
With the naked Burletta safely tucked into your inventory or backpack, deploy into the Buried City map. Your radio will crackle with a message from Tian Wen pointing you toward the Outskirts at the northern/northeastern edge of the map.
The drop zone sits directly between the Gas Station and the Hospital, just south of the Su Durante Warehouses. This open area is a notorious PvP bottleneck, so clear the surrounding rooftops of enemy players and heavy ARC machines before making your approach.
4. Stash the Pistol and Plant the Bug
Look for a heavily rusted, sand-camouflaged metal container hidden between tall industrial platforms and a partially destroyed vehicle with a distinctive blue bench nearby.
Approach the cache and press the interact button to deposit the stock Burletta.
Crucial Step: Do not sprint away immediately. You must move to the back of the exact same container and interact with it a second time to plant the tracker bug.
5. Final Extraction
The moment the bug is planted, the quest officially registers as complete. Even if you get ambushed and eliminated by a rival squad five seconds later, the progress is saved. However, to safely keep any secondary loot you've gathered, move quietly to the nearest Metro extraction point. Back at Speranza, check your trader screen to claim your permanent Burletta Blueprint, allowing you to craft the weapon indefinitely at the Gunsmith using basic mechanical components and simple gun parts.
FlameViper в оффлайне Old Post 05.06.2026 04:13
Время на форуме соответствует Гринвичу . Сейчас время - 23:56. Новая тема   Ответить
