Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Art'n'Fiction > Fan Art > When is it and which trains are running?
geemong
На форумах с июня 2022
https://ichef.bbci.co.uk/news/976/cpsprodpb/3737/production/_125553141_gettyimages-1241422731.jpg
Rail passengers are facing severe disruption this week.
สล็อตKeno is the perfect choice for beginners, since it only involves selecting numbers. After you select the dress, the drawing will occur. Match the numbers correctly and you will win.
A greatly reduced train service is in place because tens of thousands of railway workers are striking over pay and job cuts.
When are the rail strikes?
The strikes are on Tuesday, Thursday and Saturday.
Disruption is also expected across England, Scotland and Wales on other days, because of the time it takes to restore a normal service. Services in Northern Ireland are not affected.
How many trains are running?
Passengers are being advised not to travel on strike days unless it's essential.
A map has been published showing the lines operating and a special timetable up to 25 June is in place.
On Tuesday, half of the rail network was closed and only 20% of services were running.
Trains that were running started later and finished much earlier - between 07:30 and 18:30.
There were no passenger trains north from Glasgow or Edinburgh, none to Swansea and Holyhead and no trains to Penzance.
A similar impact is expected on Thursday. On non-strike days, service levels will vary between different operators.
geemong в оффлайне Old Post 23.06.2022 02:51
Посмотреть профайл автора Click here to Send geemong a Private Message Найти еще сообщения от geemong Добавить geemong в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 23:04. Новая тема   Ответить
