Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > The Matrix > Guide To Play Over/Under Betting in Soccer Betting
harimacgai23
На форумах с Aug 2023
Местонахождение: London
What is Over/Under Betting? How do you play this type of bet, and where can you bet with the most reputable bookmakers today?
Among the most popular soccer betting types, Over/Under betting is often at the top of the list. With a straightforward gameplay and attractive odds offered by bookmakers, many bettors prefer this type of bet.
Based on predicting the total number of goals in a match, players wager on what they believe is the most suitable odds. When combined with advanced skills in reading odds and expert analysis, you can ensure profitable outcomes when betting with online bookmakers.
Let's dive into this article to understand the concept of Over/Under betting and explore expert tips from experienced bettors.
Watch now: over/under 2.5 goals tips
Everything You Need to Know About Over/Under Betting
Concept
Over/Under betting, also known as Totals betting or O/U, is a major type of wager in the betting market of reputable bookmakers. Nearly every bookmaker offers this type of bet.
In Over/Under betting, players wager on the total number of goals scored by both teams in a 90-minute match, including injury time. However, extra time and penalty shootouts are not included.
Rules in Over/Under Betting:
Over (O): The total number of goals must exceed the bookmaker's given odds.
Under (U): The total number of goals must be less than the bookmaker's given odds.
Push (Draw): The result matches the odds provided by the bookmaker.
Each bookmaker offers different odds, so players need to understand and be aware of the rules specific to each bookmaker. This helps mitigate risks and maximize winnings.
Common Types of Over/Under Betting
Over/Under 1/1.5
If there are two or more goals scored in the match, players who bet on Over will win.
If there is only one goal scored in the match, players who bet on Under will win half the wager, while those who bet on Over will lose half.
If there are no goals scored in the match, players who bet on Under will win.
Over/Under 1.25
This bet is placed during the first 45 minutes of the match.
If no goals are scored in the match and you bet on Under, you win. If you bet on Over, you lose.
If there is one goal scored in the match, players who bet on Over will win half the wager.
If there are two or more goals scored, players who bet on Over will win, and those who bet on Under will lose their entire wager.
Over/Under 1.5
If there is only one goal scored in the match or if it ends in a draw, players who bet on Under will win.
Over/Under 1.5/2
If there are three or more goals scored in the match, players who bet on Over will win.
If there are two goals scored in the match, those who bet on Over will win half the wager. Those who bet on Under will win if there are 0-1 goals.
If there are 0-1 goals scored in the match, players who bet on Under will win, while those who bet on Over will lose.
Over/Under 1
This ratio is typically the easiest to play for beginners because it's easy to remember.
If there is one goal scored in the match, the bet is a draw.
Over/Under 1.5
If there are more than 2 goals in the match, those who bet on Over will win.
If there is only 1 goal scored, those who bet on Under will win.
https://www.worldcasinodirectory.com/images/content/the-basic-betting-on-football-image1_1589316154920.jpg
Find out more : soccer tips app
Tips for Winning Over/Under Betting
Play 1st Half Under
Choose odds with a PK (Pick'em) close to 100.
The PK odds for both teams should not have a significant difference.
Select the Under option with a goal difference greater than 1 compared to the bookmaker's odds.
For odds ranging from 1/1.5 and above, even if you choose Under and it ends up as a draw, you will still win half the wager.
Play 1st Half Over
The PK odds should be under 80 for the Over option and over 200 for the Under option.
Opt for odds like 1.1/1.5 and 1.5 for higher winning chances.
Avoid placing additional bets on Over if it has already won.
Additional Tips
Wait for the match to start for at least 10 minutes before placing an Over/Under bet.
For beginners, avoid employing aggressive strategies like overloading on Over or Under bets, as they are riskier and can lead to losses.
Learn to manage your bankroll wisely. Allocate your capital appropriately and aim to make more profit with less initial investment.
Invest time in gaining knowledge and information about your favorite teams. Being well-informed about your chosen team, including key goal scorers and their playing style (attack or defense), can boost your confidence when placing bets.
Combine Over/Under betting with strategies like progressive betting to multiply your bankroll.
Avoid putting all your capital into a single bet.
Seek additional betting expertise from forums, communities, or other online sources.
What is a football tip? See now : soccer tips telegram
Conclusion
Over/Under betting is an exciting and straightforward betting type that can yield high profits when done right. To be successful in this type of bet, players should learn to read bookmaker odds, employ effective analysis methods, and select odds that match their bankroll. Combine these strategies with sound betting practices for a better chance of beating the bookmakers.
harimacgai23 в оффлайне Old Post 03.10.2023 01:41
Время на форуме соответствует Гринвичу . Сейчас время - 18:49. Новая тема   Ответить
