Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > Greubel Forsey Balancier 3 Titanium
yokwoli
На форумах с декабря 2023
Greubel Forsey Balancer 3 Greubel Forsey opens a new door to its world: Balancier 3. This best fake watches joins the Convex series with a more refined appearance. Featuring majestic arches, this skeletonized titanium piece is crafted in multiple layers and is available in black or blue finishes. Stronger and more affordable, while reinforcing Atelier's high-precision timekeeping standards and finishes.
Greubel Forsey has spent nearly 20 years meeting this challenge to produce a new, more accessible timepiece with a unique identity. To achieve this, the studio needed to start from scratch. How do you create a watch with a comfortable diameter that fits an Atelier Manufacture movement? How can you make it more affordable when the piece still needs to be 100% hand-finished? Balancier 3 answers all these questions.
The first is style. From the beginning, the work was characterized by its three protruding bridges, the first of which houses the barrel, the second of which houses the large balance wheel, and the third and most striking bridge. Notably, it is connected to a seconds counter and supports hours and minutes display. replica watches for men
All of these bridges feature Greubel Forsey's signature handcrafted finish. Curved polished surfaces, polished bevels and hand polished screws. Each bridge plate features sharp internal corners and curved contours, making the hand-finished finish particularly complex – details sure to be appreciated by collectors
This design is part of the Convex range. Balancier 3 features an iconic shell that's slimmer than before. Its lugs no longer have screws – a first for Greubel Forsey. The convex case has contours on both the back and the display, making it truly unique in fine watchmaking. The product naturally molds to the curve of the wrist, providing complete comfort. On the dial side, the double curvature slopes towards the ends of the strap, creating a highly aesthetic volume that the movement uses to unfold itself. replica best watches
Then, there was movement. It imbues the timepiece with a dynamic, contemporary style and offers impeccable precision, while still being Greubel Forsey’s most affordable creation. To achieve this, Greubel Forsey once again called on the extensive expertise of its team. The idea was to create a simple, streamlined and modern design that allows you to appreciate the finish of each movement component. With this in mind, Atelier focuses on the technical nature of its timepieces. From the source of energy to the escapement, barrel and large balance wheel that drive it. Master the essence of time
Two fast-rotating barrels in series (one revolution every 32 hours) are clearly visible and decorated with the distinctive rotating graphic design that has become a staple of the Convex range, and together they provide 3 days of chronometric power store. The replica luxury watches will continue to run for many more hours, but may not achieve the accuracy required by Greubel Forsey. For the first time in the Convex series, the power reserve is displayed on the case back.
On the other side, the large balance wheel – the “Balancier” (hence the name of the watch) – is located between 4 and 6 o’clock. Conveniently integrated into the design, this Greubel Forsey variable inertia balance is balanced with 6 gold averaging time screws. It has Atelier’s signature large diameter of 1 2 6 mm, one of the most imposing diameters in contemporary fine watchmaking. Its vibrations echo the small seconds dial at 8 o'clock and its fixed indicator, which is actually the disc underneath, satin-finished. Hand, rotates and marks elapsed seconds
Finally comes the finishing touch. The wide bridge supporting the hour and minute hands is a prime example of this. Its curved three-dimensional skeleton design, multiple levels, numerous sharp internal angles and delicate arms connected to the small seconds hand are truly masterpieces. Its extremely complex geometry is perfectly matched by its hand finishing. This craftsmanship is reproduced on both sides of the barrel bridge and the balance bridge, which are beautifully hand-polished and have the same convex surface as the case that houses them.
The Balancier 3 is available in black and blue versions with a diameter of 41.5 mm, and can be equipped with a rubber strap or a Greubel Forsey titanium bracelet upon request.
Replica Patek Philippe Complications Watches
replica Jacob & Co. ASTRONOMIA THE CLARITY
Greubel Forsey Balancier 3 Titanium Limited Edition Technical Specifications
Manual winding movement • Hours and minutes • Small seconds • Power reserve • Greubel Forsey balance system
move
Movement size
Outer diameter: 35.80mm
Thickness: 9.03 mm
Number of parts: Movement: 282 parts
Number of gems: 43
Olive dome jewelry in gold sleeve
Observatory power reserve: 72 hours
Barrel: Two fast-rotating barrels in series (one revolution in 3.2 hours), one of which is equipped with a straw spring to avoid excessive tension
Embossed text, circular pattern, black treatment
Balance: In-house variable inertia balance with 6 gold mean time screws (1 2.60 mm diameter)
Frequency: 21'600 vibrations/hour
Hairspring: cross terminal curve
Geneva style studs
Bridge board and main board:
titanium
Matte, polished chamfers and countersunk holes, finished in black or blue depending on version • Multi-layered polished openwork arches, polished chamfers and countersunk holes
sports surface
Frosted bridges, polished edges and countersunk holes
Gold plated, engraved with limited number, circular graining, polished chamfers and countersunk holes, ruled sides
Gear transmission: involute scalloped tooth shape
monitor
Hours and minutes on a suspension arch bridge
small seconds hand on disc
Sector power reserve (movement side)
case:
Titanium with curved synthetic sapphire crystal
Three-dimensional variable geometry bezel, hand-polished with hand-ruining
Special shaped lugs
yokwoli в оффлайне Old Post 21.12.2023 01:14
Посмотреть профайл автора Click here to Send yokwoli a Private Message Домашняя страница yokwoli Найти еще сообщения от yokwoli Добавить yokwoli в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 19:05. Новая тема   Ответить
