Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > The Matrix > Understanding and Winning with Over/Under in Football Betting
nhuy5656
На форумах с января 2024
What is Over/Under?
Speaking of what Over/Under in football betting is, surely no one is unfamiliar with this popular term. It is also known as O/U, an abbreviation for Over/Under – quite simple and easy to understand, isn't it!
According to research by Wintips, the term "tài xỉu" (Over/Under) commonly used by bettors today originates from China, meaning "big - small". In English, it is called "Over – Under". Over means above, Under is below. Thus, even the name of this term accurately reflects the nature of this betting line.
[img]https://lh7-us.googleusercontent.com/ 7ffn_2HYxoJ6y9QhEA2UjfAThqEreAohRTU5ooXSdshJQlPL1w
rquauQpwDpGc51weaiNCeVwU-CVJtpp9dok2A- hc1d6dbUB1EPFzaXetnLbLq_0FI8DyymDbi8885qPLGm2dkelD
QXkLxY39zdjcw[/img]
Regarding the Over/Under football betting:
The bookmaker will set a specific goal threshold (a benchmark number) depending on each match.
The task of the player is to rely on this benchmark number of the bookmaker to make their prediction about the total number of goals in the actual match being higher (choose Over) or lower (choose Under).
Thus, in Over/Under football betting, bettors have two choices for placing bets: Over and Under. Bettors need to accurately predict the total number of goals and make a smart betting decision.
Different from traditional casino Over/Under games with dice, football Over/Under depends entirely on the total number of goals scored by both teams in a match, regardless of who wins or loses.
An interesting point in Over/Under betting is that all numbers are calculated based on the match score, and it will not be easy to predict what will happen. Therefore, it always brings challenges along with its appeal to players.
How to Read Over/Under Football Betting Odds: A Compilation of Basic Knowledge
As Wintips mentioned, in the field of football betting, besides Asian and European handicaps, the Over/Under (O/U) betting is also one of the most popular choices. In Over/Under betting, players wager on the total number of goals scored in a match.
Understanding Over/Under football betting is quite straightforward. For example, with a score of 2 – 0, the total number of goals is 2 + 0=2, and with a score of 5 – 1, the total is 5 + 1=6. With Over/Under betting, you don't have to be concerned about which team will win, but rather predict the total number of goals scored in the match.
However, it's important to note that Over/Under betting only counts goals scored during the official match time (90 minutes plus added injury time). Goals scored in penalty shootouts or extra time are not included in the final result.
To make it more interesting for players, bookmakers now offer a variety of Over/Under football betting options, such as betting on the first or second half, or on a 15-minute period, etc. The odds for Over/Under bets are set by the bookmakers along with different goal line options depending on the match situation.
The calculation for Over/Under football betting is also quite simple. You just take the total number of goals in the match and subtract the benchmark number set by the bookmaker. If the result:
= 0.5, players who bet on Over win the entire stake, while those who bet on Under lose all.
= 0.25, the Over bet wins 50% of the stake, and the Under bet loses 50%.
= 0, this is considered a draw, and players who bet on either Over or Under get their stake refunded.
= -0.25, the Over bet loses 50% of the stake, while the Under bet wins 50%.
<= -0.25, the Over bet loses the entire 100% stake, and the Under bet wins it all.
To help you understand better, Wintips shares with you the most popular way to read Over/Under football betting odds in the betting world today:
Over/Under 1.5
The Over/Under 1.5 bet is also known by other names such as 1 ½ Over/Under, or 1 and a half goal Over/Under.
To understand the Over/Under 1.5 bet, you need to comprehend the meaning of the number 1.5 in this context. The number 1.5 represents the total number of goals predicted by the bookmaker for a match. Therefore, if the total number of goals in the match is 2 or more, the Over bet wins, but if the total number of goals is 0 or 1, then the Under bet triumphs.
For example: If an Over/Under 1.5 bet is placed on a match between Manchester United and Liverpool, and the final score of the match is 2-1 in favor of Manchester United, the total number of goals scored by both teams is 2+1=3. In this case, those who chose Over would win the bet. Conversely, if the score of the match were 1-0, 0-0, or 0-1, then the Under bet would win.
Additionally, it's important to note that the Over/Under 1.5 bet can also apply to a specific half of a match, such as the first or second half. In this situation, the principle for reading the bet remains the same, but the total number of goals will be counted only within the time to win prediction frame of that specific half.
Over/Under 1.75
The Over/Under 1.75 bet, also known as 1 ¾ Over/Under or Over/Under 1.5 - 2, is often seen in matches from leagues like the Spanish Second Division and French Second Division. These are leagues that emphasize tactics and usually feature few goals. To understand and interpret this type of bet, consider the following information:
Over bet: If the total number of goals scored in the match is 3 or more, the Over bet wins the full amount (full win). If the number of goals scored is 2, those who chose Over win half of their bet amount. If the number of goals scored is 1 or 0, the Over bet loses.
[img]https://lh7-us.googleusercontent.com/mCbWig4KvZEc7bMJiWszjL_MRUiOgCNZDrTAS- Mez_byL7u5Af1Xopj24ltko_N2LOANeSFYv_6AEPdVInkrKFA4
3CsNXnDV7ejyD8tOxvcos9ojUhBYE8KbRzjvfyLuEl7fW167uc
cmjNt3ZK5HV14[/img]
Under bet: If the total number of goals scored in the match is 0 or 1, the Under bet wins. If the number of goals scored is 2, you lose half of your bet amount. If the number of goals scored is 3 or more, you lose your entire bet.
Example:
If the match ends with a total of 2 goals, and you placed a bet on the Over at the 1.75 threshold with $100, you win 50% of your bet amount, meaning you win $50. If you placed a $100 bet on the Under at 1.75, you lose 50% of your bet amount (lose $50).
If the match ends with a total of 3 goals or more, and you placed a $100 bet on the Over at 1.75, you win the total amount of $100 times the odds for the Over/Under 1.75 bet. If you placed a $100 bet on the Under at 1.75, you lose the bet.
Over/Under 2
In the usual Over/Under bets you encounter in football betting, bookmakers often set odd numbers. However, there are many cases where even Over/Under benchmarks like 2, 3, 4, etc., occur. In such cases, the way to read Over/Under football betting odds is as follows:
The Over bet wins if the match ends with more than 2 goals (3, 4, 5, etc.).
The Under bet wins if the match ends with fewer than 2 goals (0 or 1).
Both sides draw if the match ends with exactly 2 goals scored (1-1, 2-0, or 0-2).
Over/Under 2.25
The 2.25 betting level is also known as Over/Under 2 ¼ or 2 – 2.5. This is one of the more challenging betting levels to predict, requiring players to have knowledge about the team, playing style, performance, and experience in assessing the odds.
Here's how to interpret the 2.25 betting level:
If the match has 3 or more goals, the Over bet wins the entire staked amount.
If the match has exactly 2 goals, the Over bet loses half of the staked amount, and the remaining half is refunded.
If the match has fewer than 2 goals, the Under bet is the winning side.
Other Over/Under Levels (2.5, 2.75, 3…)
Just by memorizing the Over/Under calculations for betting lines like 1.5, 1.75, 2, 2.25, you can easily apply the same rules for Over/Under levels of 2.5, 2.75, 3, 3.25, etc. If you encounter any difficulties, you should use the formula provided by Wintips in the section on how to read Over/Under football bets 1x2 odds.
Guide to Playing Over/Under in Football Betting: Win Every Match with the Ultimate Tips and Tricks
To assist our fellow bettors in increasing their chances of winning in this "easy to play, easy to win" betting line, Wintips shares some valuable experience for your betting journey. Specifically:
Firstly, determine your own style of Over/Under betting. In the betting world, bettors are often divided into two schools: one specializes in Over bets and the other in Under bets. You need to know which betting line suits you best.
After determining your preferred approach, choose leagues that match your favorite betting style. If you like betting on Over, choose leagues where goals are more likely and matches are open, such as the Norwegian, Mexican, Dutch, Swedish, and German (Bundesliga) leagues, or matches involving big teams with strong offenses like Man City, Bayern Munich, PSG, Barcelona, Liverpool, etc.
If you opt for Over bets, consider betting after the first 10 minutes of the match as goals are less likely to be scored during this period, leading bookmakers to lower the odds. This increases your chance of winning.
Conversely, if you prefer Under bets, choose leagues that are more tactically oriented, where matches are tight, and the attacking prowess of teams isn't very sharp, such as the Spanish Segunda Division, English EFL Championship, French Ligue 2, etc.
More importantly, in any betting line, not just football Over/Under, you must always analyze the necessary statistics thoroughly before each match, along with observing the odds movement online to make accurate predictions. Develop your own “case studies” from real experiences and apply them in future bets.
For example, take the Premier League match between Everton and Brentford on 11th March 2023. A day before the match, the bookmaker set the Over/Under at just 2.25 with an Over bet at 2.1 odds. This was a low Over/Under level considering the defensive and offensive form of both teams.
Everton had one of the weakest defenses in the league, and Brentford was known for their attacking play, leading to high-scoring matches. Thus, the 2.25 level with high Over odds offered by the bookmaker was too low. Especially close to the match, the Over/Under was further reduced to 2 with an Over bet at 9x odds.
In such cases, the bookmaker likely sensed something and predicted a low-scoring match. The right choice for bettors at that moment was the Under 2 bet. The match played out as expected, with Everton scoring early in the 2nd minute, but no more goals were scored for the remaining 90 minutes, making the Under bet an easy win.
Therefore, we have helped you understand what Over/Under betting is, along with how to read football tips win Over/Under bets simply, and some tips for winning in this type of betting. If you enjoy topics like this, feel free to leave a comment below and don't forget to follow Wintips for more interesting articles!
https://wintips.com/bookmakers/
nhuy5656 в оффлайне Old Post 25.01.2024 11:48
Посмотреть профайл автора Click here to Send nhuy5656 a Private Message Домашняя страница nhuy5656 Найти еще сообщения от nhuy5656 Добавить nhuy5656 в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 15:33. Новая тема   Ответить
