Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > The Matrix > Last Epoch Falconer Build Guide
jacksoner
На форумах с марта 2024
Местонахождение: aa
If you're looking for the best Last Epoch Falconer build, this Bird Whisperer class has amazing damage potential, but it requires a lot of powerful Falcon attacks and a lot of careful maneuvering. The bird may not be harmed, but the Falconer is still a rogue class that relies on the ability to move quickly. To help you stay active while your birds go on a killing spree, here are some tips for getting the best Last Epoch Falconer build.
The Last Epoch Falconer class is a master rogue that combines minion gameplay with explosives. Your fellow falcon has a variety of attacks, with dive bombs being particularly powerful. As long as you buff the Falcon's attack and reduce its cooldown, you already have a powerful Falcon build.
Since this class is so vulnerable, a good Last Epoch Falconer build should include movement speed abilities. Shift is a good choice early in the game, but this guide will replace Shift with Air Assault. You should use the additional Field of Effect ability, Smoke Bomb, to reduce damage taken and enhance your attacks.
No matter how powerful the build is, you need to have enough Last Epoch Gold to complete your build. It just so happens that the trading system of Last Epoch has been opened now. You can try to buy Last Epoch Gold. I can recommend you a good place to buy Gold - IGGM.
Bonus: Coupon Code "Long" (5% OFF) can be used at IGGM.
a
jacksoner в оффлайне Old Post 11.03.2024 06:08
Посмотреть профайл автора Click here to Send jacksoner a Private Message Найти еще сообщения от jacksoner Добавить jacksoner в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
cofffee124
На форумах с Aug 2024
Most people like using sex dolls, and most people like considering using big boobs sex dolls
Adult dolls can be used in any environment and enjoy unlimited.
cofffee124 в оффлайне Old Post 23.02.2025 22:19
Посмотреть профайл автора Click here to Send cofffee124 a Private Message Домашняя страница cofffee124 Найти еще сообщения от cofffee124 Добавить cofffee124 в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 16:58. Новая тема   Ответить
