Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > HYT T1 Series
yokwoli
На форумах с декабря 2023
HYT T1 Series
HYT celebrates 12th anniversary as well as launches T1 series
New series with smaller houses for the first time
HYT is an spectacular Swiss copy luxury watches brand noted for pioneering the use of fluid engineering in timekeeping. At the heart associated with HYT's innovation lies some sort of patented system called “microfluidics” that revolutionizes the exhibit of time. As we've viewed with the Lunar Landscapes, Hastroid Blue Star, and Hastroid In Silver Red, HYT uses fluid instead of classic hands or digital features, giving their watches an exceptional futuristic look.
To celebrate HYT's 12th anniversary, the brand starts the T1 Collection, the latest collection with a smaller 45 millimeter case diameter. Introducing brand-new designs and a new coloring spectrum, the spirit on the times is encapsulated by way of four new references.
Typically the T1 series launches using two case options, one out of titanium and the other throughout titanium. Titanium cases come in salmon, anthracite and gold dials, while sophisticated platinum and DLC titanium circumstances adorn midnight blue watch dials. All in a new diameter regarding 45mm, which as HYT mentions in the press release “ushers in a new chapter to the brand”. Each watch within the new collection is 19. 20 mm thick and also comes with a black DLC covering. Additionally , it features a sky-blue crystal with an anti-reflective finish to protect the dial. replica Tudor Black Bay
The brass face features a rhodium-plated power reserve hands between 2 and several o'clock. The time display technique operates via the travel of two highly accommodating and durable bellows. When a single reservoir containing a colored aqueous liquid expands, the other depository is compressed and the other way round, thereby facilitating the activity of fluid through the capillary tubes.
This mechanism presents the passage of hrs by "pushing" the hued liquid, causing the column inside the capillary to gradually grow to be taller, while "pulling" typically the clear viscous liquid reasons the column to become proportionally smaller. The meeting place of the two liquids kinds a half-moon meniscus in which indicates the hours about the scale. When it reaches often the 6 o'clock position, the actual colored liquid column results to its original location. The minutes are mentioned by a rhodium-plated polished key hand coated with bright Super-LumiNova. replica Jacob & Co. watches
This timepiece is powered by the 501-CM manual winding movement, which often beats at 28, 500 vibrations per hour (4 Hz) and provides a 72-hour reserve of power. The movement combines covered and sandblasted finishes, causing the overall beauty and care about detail.
Technical Specifications: HYT T1 Series
case:
Ti or titanium case, african american
DLC
Coated, sapphire very with anti-reflective coating
height:
45mm
high:
17. thirty mm
Water resistance:
50 metres
dial:
Salmon, Anthracite or maybe Silver (Titanium), Midnight Orange (Gold and DLC Titanium),
brass
dial,
Rhodium plated
Power reserve hand between only two and 3 o'clock, rhodium-plated and polished center palm, white
super luminous
, water
Retrograde
Hour
move:
501-CM movement, manual winding,
Covered
and
sandblasting
Finishes, forty one stones, 352 components
Reserve of power:
72 hours
Frequency:
36, 800 times/hour (4 Hz)
Function:
Fluid retrograde several hours, central minutes, power reserve sign
Bracelet/strap:
Black rubber secure with titanium or 5N gold pin buckle
replica bugatti watch
replica high quality watches
replica Urwerk Watch
https://www.chronowrist.ru/images/HYT%20H1%20watch%20148-VG-10-GF-RA.jpg
https://www.chronowrist.ru/images/Tudor%20Black%20Bay%20watch%20M79230R-0012.jpg
https://www.proreviewwatch.co/images/Urwerk%20replica%20UR-105TA%20Black%20Orange%20watch.jpg
yokwoli в оффлайне Old Post 08.04.2024 02:46
Посмотреть профайл автора Click here to Send yokwoli a Private Message Домашняя страница yokwoli Найти еще сообщения от yokwoli Добавить yokwoli в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 18:43. Новая тема   Ответить
