Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Humour > Hublot replica watches
yokwoli
На форумах с декабря 2023
Hublot's first limited edition BIG BANG UNICO left crown ceramic chronograph reverses tradition
Hublot, the top Swiss watchmaking brand with "The Art of Fusion" as its brand spirit, took the lead in the world in Taiwan in 2024 and launched the first left crown best replica watch site equipped with UNICO movement for the first time: Big Bang Unico Left Crown Ceramic Chronograph. Patented high-end ceramic creates a matte white ceramic case and a contrasting red ceramic bezel. It uses the crown and pusher on the left side to reverse the design of traditional sports watches. It has a flyback chronograph function and a 72-hour power reserve. The open hollow dial displays the redesigned movement layout, allowing the sophisticated mechanical structure to be seen at a glance. It combines avant-garde aesthetics and efficient sports performance. It is the most innovative UNICO movement since its launch. A masterpiece that demonstrates Hublot’s outstanding achievements and unique ingenuity in watchmaking technology.
Since the launch of the first completely self-made UNICO chronograph movement in 2010, it has established an unshakable benchmark position in the field of professional watchmaking with its excellent watchmaking skills and avant-garde aesthetics. The Big Bang Unico Left Crown Ceramic Chronograph continues this legend, combining the brand’s technical prowess with avant-garde aesthetics. The watch’s skeletonized dial showcases the redesigned movement layout, revealing the intricacies of the internal mechanical structure. Equipped with a flyback chronograph function and a 72-hour power reserve, this buying replica watch represents one of the most innovative performances of the UNICO movement to date, demonstrating Hublot's commitment to continuously breaking through watchmaking technology.
The name of the UNICO movement comes from "Unique", which is Hublot's unique and distinctive brand core value. This spirit is fully reflected in the carefully designed layout of the Big Bang Unico Left Crown Ceramic Chronograph. Every detail from the operating mechanism on the front to the transparent case back has been crafted with precision. The iconic column wheel is located at 12 o'clock, and the 60-minute counter and date window are set at 9 o'clock. The double-oscillating clutch and silicon escapement located between 1 o'clock and 2 o'clock clearly demonstrate the meticulous engineering design behind this movement. The special-shaped patented fine-tuning system can accurately adjust the effective length of the hairspring through the serrated screw set, making the travel time more accurate. The aesthetic fine-tuning system not only has a clearly visible structure, but also cleverly incorporates the "H" brand logo. "Full Adjusted" engraved on the back of the case means precise adjustment across five directions, ensuring high accuracy. replica Patek Philippe Grand Complications
The UNICO flyback chronograph movement has laid the cornerstone of Hublot's professional watchmaking factory. Its excellent performance and avant-garde aesthetics are perfectly integrated. It has been used in the Big Bang Unico series and Square Bang Unico series, and now it is also equipped with the first limited edition left crown surface. This watch not only redefined the design of traditional chronographs, but also set new performance standards and became a must-have treasure for collectors.
Hublot ensures that the UNICO movement improves the accuracy and performance of the watch through multiple patents. One of them is the oscillating seconds clutch mechanism, which adjusts the clutch structure. It uses the swing angle and elasticity of the double gears to avoid vibration and errors, eliminate the common initial jump defects in horizontal clutch chronographs, and provide better performance than traditional Designed for more precise control and smoother operation. The stop and zero-reset functions of the UNICO movement are precisely controlled by a column wheel. However, the pursuit of ultimate excellence does not stop there. It is also equipped with a mechanical device that supports flyback function. When the button at 10 o'clock is pressed, the second and minute hands during the timing process will immediately stop timing, and the moment the button is released, the timing hands will return to zero simultaneously and restart the timing. In addition, the performance of the UNICO movement is also excellent in daily functions. It is equipped with a semi-instantaneous jump date display window. The movement is equipped with a clutch device, allowing the wearer to adjust the date at any time without causing damage to the movement. The stop-seconds function meets the need to adjust time accurately to the second. richard mille nadal
Another patented design of the UNICO movement is that through the screw in the center of the automatic plate, the friction force exerted by the ceramic ball on the timing wheel can be finely adjusted. In this way, the watchmaker can find the optimal friction force through fine-tuning work. Balance point to avoid excessive torque causing the watch to run too slowly, or too weak torque causing the chronograph hands to vibrate.
With its powerful performance, the bezel design of the Big Bang Unico left crown ceramic chronograph is even more ingenious. The high-quality matte white ceramic case is paired with a matte red ceramic bezel, while the side ring of the bezel is made of mirror red ceramic. The multi-layered design not only adds a harmonious and refined sense of frontal vision, but the polished red ceramic of the side ring is like the finishing touch. It makes the wearer shine with his hands. This white-based watch presents an eye-catching futuristic trend style with its innovative appearance design. However, under the eye-catching appearance, it contains fine workmanship and is restrained. Without losing style, it perfectly fits the spirit of dynamic sports. breitling bentley replica watches
The 42 mm patented high-tech ceramic case is cleverly integrated with titanium pushers and white rubber lugs that protect the case. It not only presents strong and durable qualities, but also demonstrates a pragmatic design concept. The three-day power reserve and certified waterproof depth of 100 meters give the watch excellent durability and waterproof performance. Whether facing the natural environment or spending the weekend with family and friends for leisure, it is the ideal companion. jacob & co astronomia price
yokwoli в оффлайне Old Post 28.08.2024 04:02
Посмотреть профайл автора Click here to Send yokwoli a Private Message Домашняя страница yokwoli Найти еще сообщения от yokwoli Добавить yokwoli в Ваш список друзей Ответить с цитированием Редактировать/Удалить сообщение
Время на форуме соответствует Гринвичу . Сейчас время - 21:28. Новая тема   Ответить
