Форум Ложки.net - Все о Матрице : Powered by vBulletin version 2.2.8 Форум Ложки.net - Все о Матрице > Сайт и форум > Альтернативная Матрица > Forza Horizon 6: Complete Strategy for Hakone Nanamagari Touge Race
FlameViper
На форумах с июля 2025
Map Location & How to Unlock
The Hakone Nanamagari Touge event is located just north of the Irokawa Space Centre, in the southwestern corner of the Japan map. If you can’t see the event icon or it’s hidden under the green fog:
Earn Stamps and Wristbands: Progress through the Discover Japan Stamps until you reach the Blue / Traveller Stamp tier. This will trigger most hidden event unlocks.
Drive to the Location: Take your vehicle directly to the greyed-out roads in Nangan. Once there, the fog clears, and the Hakone Nanamagari Touge race becomes available.
Hidden Barn Find: While exploring, check just west of the Touge route to discover a barn housing the 1971 Nissan Skyline 2000GT-R. It’s a great bonus for your garage and a fun car for subsequent races.
Best Car Setup & Tuning Strategy
Success on this touge relies on how your car handles corners, not its straight-line speed. For Series 1’s "Gazoo Racer" Summer Weekly Challenge, the 2022 Toyota GR86 is required, but the following principles work for any vehicle:
Tires and Suspension: Use Race or Horizon Drift suspension to maximize grip and agility. Sport or semi-slick tires work best for speed-focused runs, while drift tires are ideal for tackling the adjacent Drift Zone.
Brake Bias and Force: Increase braking force to around 110%–120%. This allows late braking for aggressive overtakes, especially in critical hairpins like Turn 1 and Turn 10.
Differential: A deceleration lock of 20–30% stabilizes the rear when braking downhill, keeping the car predictable through sharp turns.
Race Strategy & Cornering Techniques
The AI is defensive and the roads are narrow, so positioning and timing are critical:
Secure an Early Lead: Attack the inside line on Turn 1 to gain position immediately. Once ahead, adopt a defensive line to maintain control without risking spins.
Manage Weight Transfer: The hairpins are tightly packed. Lift off the throttle slightly before the apex to settle the front tires, then accelerate smoothly out of the corner. Avoid drifting unnecessarily on standard races, as losing traction costs uphill momentum.
Out-Brake the Competition: Drivatars often brake too early into sharp hairpins (notably Turn 1, Turn 7, and Turn 10). Trail-brake into the apex and stick to the inside line to pull away cleanly.
Conquering the Hakone Nanamagari Drift Zone
If your goal is to tackle the Drift Zone’s 340,000-point 3-star challenge, the approach changes completely:
Drive Downhill: Starting your drift from the top provides momentum for wider angles and higher scores.
Minimize Transitions: The hairpins are close together, so rather than weaving, maintain extended drift angles through main corners to keep multipliers active.
Assist Settings: Turn off Traction Control and Stability Management to avoid engine power cuts during slides, giving you maximum control over drift angles.
Final Tips
Familiarize yourself with the sequence of corners before racing seriously.
Use practice runs to test braking points and line choices.
Remember, smooth weight transfer and precision beats raw speed. Master these, and Hakone Nanamagari will be your playground.
With careful setup and strategic driving, the Hakone Nanamagari Touge Race can be conquered consistently, whether you’re racing for a weekly challenge or chasing Drift Zone glory.
FlameViper в оффлайне Old Post 22.05.2026 03:36
Время на форуме соответствует Гринвичу . Сейчас время - 12:54. Новая тема   Ответить
